XXXterra's 2005 xterra build log- PSI 8s, nendo mids & highs, IA & nendo amps, 80PRS- Playing!
Currently working on my 4th build, guess Ill start off with some pics of the vehicle and the previous systems...
2005 Xterra SE w/ 285/75/R17 Firestone Destination A/Ts, 2" PRG lift and DT long tube headers.
First build:
2x kicker comp 12s, sealed, Alpine type R coax all around on kicker zx700.5
Second Build:
RE XXX 15" on an aq2200d, massive audio RK6 components all around on the zx
Third Build:
2x Crossfire XSV2 15s in BHE box, Crescendo BC5500 @.5ohm, Massive Audio RK6 comps on a Skar SK85.4
Current Build Equipment List
H/U: Pioneer AVH3200BT (for now)
Mids/Highs:
Crescendo Pwx8s (Front doors)
Crescendo Pwx 6s (Rear doors)
Crescendo Rts1 tweets (4 pairs)
Subs:
2x Psi 8s (D4, High performance option)
Amps:
Crescendo Symphony 1500
Incriminator Audio 6.4
Wiring:
Stinger HPM and Knukonceptz OFC 1/0
Stinger HPM 4, 8, 12, 16 gauge
Stinger 4000 series 6 channel RCAs
Stinger Fuse blocks and fuses
Electrical:
Kinetic HC2400 w/ Toolmake quad 1/0 Blocks
Big 3 in 1/0
2 runs 1/0
Stinger Voltage Meter
very very clean!
2004 Chevy Trailblazer LT
Walled- 10.5 cubes net tuned 33Hz
2-15 inch AA Team subs D2
Americanbass- 750.1
1 yellowtop under the hood , 4 c&d 88ah batteries in rear
mechman-270
pioneer headunit-4200UB
4 soundqubed supertweeters
phoenix gold 2 channel
back up camera
stinger volt meter
22 years old and still have alot to learn..lets get it
very very clean!
Americanbass- 750.1
mechman-270
back up camera
stinger volt meter
Tuned in. Got any videos of your last build?
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Nice x man. You could say I'm a fan of xterras I have an 02 myself. Trying to save some space this time around I see haha. Looks great man!
Build sounds interesting, like those 8s
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
I'm in to see how those psi 8's perform, they sure do look beefy though.
Yeah, Im excited. Definitely got some nice little motors on em. I wanted to go a different route than everyone with the sa8's
very very clean!
Thank you sir, but all the credit for the last build goes to Robin Butler of Bassheads ent. He did an amazing job on the box and amp rack.
This new build will be all me though!
I love em man. And yeah, need some space. Planning on some road trips and camping/mountainbike trips this summer. Also gained 2" of lift removing the 3rd build! and MPGs went up by 1.
Sweet. Ill do some digging to find em.
Got some stuff done in the past 2days...
So heres how the massives were loaded in the doors and the tweets in the dash...
Skar amp under passenger seat
Got to work and Pulled most of the front interior out...
Then had to figure out how to fit the 8s behind the stock door panels. The depth and size made it pretty hard but I came up with a 3/4" bracket with a 3/4" ring and a 1/2" ring on it to just barely clear the motor with the window. Had to do a little surgery on the backside of the panel to make it work but you can't tell from the front side of the panel. Also had to break out the 4lb sledge to make a little room for the motors to fit into the openings in the sheet metal...
Comparison of massive rk6 to pwx8(right)
Making room for motors
Bracket test fit
They work
The pwx6s for the back doors still needed new rings but these were way easier, single 3/4" ring bolted to door
Mounted upside down to be sure the terminals dont touch sheet metal
Now time to run some wires...
Wiring plans:
There will be a run of 12g to each door for the PWX6s and pwx8s. Theyll run off channels 3/4 of the IA6.4 in parallel at 2ohm seperated by right and left for stereo seperation.
There will be 3 rts-1 tweets in each A-pillar and one in each rear door. These will run off channels 1/2 series paralleled for a 4 ohm load, again seperated right and left. Each tweet will have a 16gauge lead coming off of it and will be soldered to the passive xover that comes with it all 4 passive xovers will be hidden behind the kick and soldered to a 12gauge lead from the amp.
Hoping to have all the wiring done and IA6.4 installed so I can have everything reassembled Sunday night and atleast have some music.
