SPL2K Posted March 21, 2008 Report Posted March 21, 2008 ok so as big as possible, Not if you want SPL. Quote Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
sactownstang Posted March 23, 2008 Report Posted March 23, 2008 it's not only the box like they are saying it changes each way it fires..... I have a slot ported in a crx, if ports and sub are foward it's almost a db lower then if i aim at the roof. Aim towards the rear another .5 db gain. SPL= test, change, test, change, test, rebuild and start over testing.... Quote
Derrick824 Posted March 23, 2008 Report Posted March 23, 2008 SPL= test, change, test, change, test, rebuild and start over testing.... Amen. banginAltima's current "frankenbox" has been cut, spliced, pieced, and patched more than Joan River's face. Quote
David Posted March 23, 2008 Report Posted March 23, 2008 from what I have read on the net, the jeeps like the sub and port facing the rear. to get res frequency you will need to do alot of testing, the res freq will change everytime you make a change get a 10" sub, build a 1 cube square box sealed, give this woofer 100wrms and start playing with it in the vehicle, move the box in various positions and run sweeps, write down the res freq everytime you run the sweep, it will change almost everytime you move the box in the vehicle PURE SPL is all about test test and retest then test agian Quote
sactownstang Posted March 23, 2008 Report Posted March 23, 2008 And after your about done testing...pray the amps or subs ain't damaged Quote
banginAltima Posted March 23, 2008 Report Posted March 23, 2008 Amen. banginAltima's current "frankenbox" has been cut, spliced, pieced, and patched more than Joan River's face. hey man, leave my box alone. I know it won't take first in a beauty contest but it works. sactownstang was right on... SPL= test, change, test, change, test, rebuild and start over testing.... Quote If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
