DubNDodge Posted April 18, 2014 Report Share Posted April 18, 2014 Because hes basicslly called everyone here an idiot when they tried to help him previously. To say hes got a history here would be an understatement Gotcha. Didnt know that, just see the question. http://www.stevemeadedesigns.com/board/topic/185280-crescendo-audio-worst-service/ http://www.stevemeadedesigns.com/board/topic/176319-apcl-30001d-audiopipe-amp-wtf/page-3 '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult. Link to comment Share on other sites More sharing options...
meade916 Posted April 18, 2014 Report Share Posted April 18, 2014 Like I said, check the DD-1 harness. If the wires are bad inside that RCA jack, it would be jumping the positive of the speaker output to the ground on the amplifier. I'm guessing that would cause an amplifier to go into protect, this is the only way a DD-1 can cause an amp to go into protect....damaged harness wires. Usually from being pulled too hard. Check with a DMM that the red and black are not internally shorted. If they are, email [email protected] we will get you a new one out. It's usually never damaged right out of the box, its almost always user related damage, but i don't mind getting you a new one to get you back on the road. FYI: The alligator clip has been phased out for a pair of probes due to the fact some amps tuning procedure with the DD-1 don't work properly when using the actual ground for reference. Sometimes you have to use the speaker (-) and that is ok. If your amp went into protect for any reason using the dd-1 i highly suggest you check the harness. All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916 Link to comment Share on other sites More sharing options...
Hammer Knock Posted April 19, 2014 Author Report Share Posted April 19, 2014 Like I said, check the DD-1 harness. If the wires are bad inside that RCA jack, it would be jumping the positive of the speaker output to the ground on the amplifier. I'm guessing that would cause an amplifier to go into protect, this is the only way a DD-1 can cause an amp to go into protect....damaged harness wires. Usually from being pulled too hard. Check with a DMM that the red and black are not internally shorted. If they are, email [email protected] we will get you a new one out. It's usually never damaged right out of the box, its almost always user related damage, but i don't mind getting you a new one to get you back on the road. FYI: The alligator clip has been phased out for a pair of probes due to the fact some amps tuning procedure with the DD-1 don't work properly when using the actual ground for reference. Sometimes you have to use the speaker (-) and that is ok. If your amp went into protect for any reason using the dd-1 i highly suggest you check the harness. checked harness with DMM, 001 for both POS and NEG on the harness edit: facebooked TD himself about it... here is what he said. (after giving him the serial number of dd-1) "We had a few of these early units that had a diode in them that could only handle about 80V. Please send it to us along with the test probe. Just leave your return address in the box and we will upgrade it with the higher voltage replacement parts and send it right back to you." if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
Hammer Knock Posted April 19, 2014 Author Report Share Posted April 19, 2014 So much for my non-intelligence you all thought so highly about! if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
Guest Posted April 19, 2014 Report Share Posted April 19, 2014 fuggin noobs. literally took me 30 seconds to google a thread that was posted regarding somebody elses harness going bad. same exact symptoms. except it was from a knowledgeable member you all respect so nobody was flaming him. Link to comment Share on other sites More sharing options...
audiofanaticz Posted April 19, 2014 Report Share Posted April 19, 2014 Like I said, check the DD-1 harness. If the wires are bad inside that RCA jack, it would be jumping the positive of the speaker output to the ground on the amplifier. I'm guessing that would cause an amplifier to go into protect, If the wires inside the rca harness where shorted out, they would still be shorted out while it was connected via the speaker pos to pos and speaker neg to neg, or speaker pos to pos and ground on the battery. Both methods would cause and issue. not just one or the other. Shorting something out is shorting something out. First as CJ said, I would most efficiently remove all speaker wires from the amp and retry.. Second if the issue still is there Id look into other symptoms, and would test RCA cords to make sure those are not shorted out. Id unplug them from the amp and test each rca channel on the dd1 for a clean signal, if you have a non steady signal your rcas are the cause. With how many people hot swap rcas, blow picco fuses, and blame pioneer and even other manufacutres for these kinda mistakes it wouldnt surprise me one bit that something with the rca's or the deck are causing issues. If the signal is still bad with new rcas, id next be checking the deck. If deck is fine bench test the DD1 on another amp/radio that is not in your vehicle, but a friends and see if that issue follows or if the dd1 is fine. This is called trouble shooting! Link to comment Share on other sites More sharing options...
Hammer Knock Posted April 21, 2014 Author Report Share Posted April 21, 2014 Tested DEH-64bt for distortion and signal. NOTHING. testing a friends head unit. NOTHING. tested the same friends amp for distortion. did same thing as it did on the nendo 3500. dd-1 is now sent to tony d for repair. if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
