eletrical question
I do t know what those amps pull on average but for the sub amps I would assume roughly 100-125amps each on music. That alone is 200-250. If you want to hold voltage above 13 volts you would want what you mentioned plus 2 0gauge ofc runs solid frame grounds and big 3 done with ofc. Ground the alt case to the frame or front battery.
I would rather have a bigger alt and les batts though. Something more along the lines of as 200-250 min alt more if you can find bigger.
My alt is a 170 amp but its rated at 220
What?
Meh
We'll be running around the same power.
I have ~60aH of charging power over you, and a few amperes in the reserve dept over you.
Full tilt, ill drop like .7v, while Ill drop around 1.2v at idle.
Take that for what it is...
I just want to stay above 12v
  • Who's Online   0 Members, 0 Anonymous, 6869 Guests (See full list)
