Blake Farrar Posted April 23, 2014 Report Posted April 23, 2014 Im looking to run 2 cresendo 1500s and 2 CT sounds 125.4 I curently have a 170 amp mechman alt would 3 yellow tops be enough??
ChevyBoy95 Posted April 23, 2014 Report Posted April 23, 2014 Should be. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
rockFord_Expedition Posted April 23, 2014 Report Posted April 23, 2014 I can see you've moved right along since your last thread lol. What voltage are you trying to hold? 4k is a lot for that setup. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
Kyblack76 Posted April 23, 2014 Report Posted April 23, 2014 where are you gonna load the 2 1500's to? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Tecomah Posted April 23, 2014 Report Posted April 23, 2014 Make up your mind bro 750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.^ DON'T BE A DICK LIKE THIS GUY Team Subsonic Lows
Tecomah Posted April 23, 2014 Report Posted April 23, 2014 where are you gonna load the 2 1500's to? probably like 0.12 ohms lol 750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.^ DON'T BE A DICK LIKE THIS GUY Team Subsonic Lows
alaskanzx5 Posted April 23, 2014 Report Posted April 23, 2014 I do t know what those amps pull on average but for the sub amps I would assume roughly 100-125amps each on music. That alone is 200-250. If you want to hold voltage above 13 volts you would want what you mentioned plus 2 0gauge ofc runs solid frame grounds and big 3 done with ofc. Ground the alt case to the frame or front battery. I would rather have a bigger alt and les batts though. Something more along the lines of as 200-250 min alt more if you can find bigger. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
hdorre Posted April 23, 2014 Report Posted April 23, 2014 Meh We'll be running around the same power. I have ~60aH of charging power over you, and a few amperes in the reserve dept over you. Full tilt, ill drop like .7v, while Ill drop around 1.2v at idle. Take that for what it is... On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Blake Farrar Posted April 23, 2014 Author Report Posted April 23, 2014 I do t know what those amps pull on average but for the sub amps I would assume roughly 100-125amps each on music. That alone is 200-250. If you want to hold voltage above 13 volts you would want what you mentioned plus 2 0gauge ofc runs solid frame grounds and big 3 done with ofc. Ground the alt case to the frame or front battery. I would rather have a bigger alt and les batts though. Something more along the lines of as 200-250 min alt more if you can find bigger. My alt is a 170 amp but its rated at 220
Blake Farrar Posted April 23, 2014 Author Report Posted April 23, 2014 I can see you've moved right along since your last thread lol. What voltage are you trying to hold? 4k is a lot for that setup. Like 12.5+
