Lanzar Opti7001d
BAMABOY691
Sweet thanks for sharing bro! I always been curious of what these look/sound (look internally)
  • 1,600 Watts RMS Power @ 4 ohm
3,070 Watts RMS Power @ 2 ohm
5,180 Watts RMS Power @ 1 ohm
7,000 Watts RMS Power @ 0.5 ohm
THD 4ohm Power 0.5%
0.5 ohm Stable
Frequency Response: 10Hz-250Hz
S/N Ratio (4 ohm ): 90dB
Variable subsonic: 15Hz-45Hz
Phase shift: 0~180 degrees
Variable LPF: 50Hz~250Hz
Variable Bass freq: 21Hz~80Hz
Variable Bass Boost: 16dB
Source Voltage: 9 - 18VDC
Line In & Line Out
Strap two amps together for twice the power
Nickel-plated RCA connectors & Screw terminals
Thermal, Over load & Speaker short protection
Double Side Epoxy PCB Circuit Board
Power & Protection LED Indicators
Remote subwoofer Level control
Soft Turn-on/Turn-off
Dimensions : 11.02''(W) x 2.12''(H) x 28.34''(L)
REP
  • 1 month later...
  • 9 months later...
  • Who's Online   1 Member, 0 Anonymous, 1526 Guests (See full list)
