Difference in hifonics amps?
Just wondering what the diffence is between these amps? Is it just cosmetics?
http://www.sonicelectronix.com/item_76257_Hifonics-X1200.4.html
Power Specifications - Full Range Channels
RMS Power @ 4 ohms
150 watts x 4 channels
RMS Power @ 2 ohms
300 watts x 4 channels
Bridged RMS Power
600 watts x 2 channels
Amplifier Specifications
Amplifier Series
Brutus X-14 (Hifonics)
Amplifier Class
AB
Number of Channels
4
Total Peak Power Output
1200 watts
Maximum Input Gauge Size
4 AWG
Minimum Impedance Unbridged
2 ohms
Minimum Impedance Bridged
4 ohms
Speaker Level Inputs
No
Preamp Outputs
1 pair
Built-in Crossover
Low-pass (LP)
High-pass (HP)
High-Pass Crossover Frequency
10 - 2500 Hz
Low-Pass Crossover Frequency
35 - 2500 Hz
Bass/Gain Remote
Yes
Fan Cooled
No
Fuse Rating
60A x 2
CEA-2006 Compliant
Yes
Strappable
No
http://www.sonicelectronix.com/item_67932_Hifonics-BRX1200.4.html
Amplifier Series
Brutus (Hifonics)
Amplifier Class
AB
Number of Channels
4
Total RMS Power Output
1200 watts
2 AWG
2 ohms
4 ohms
THD at Rated RMS Power
0.05%
Yes
Preamp Outputs
1 pair
Built-in Crossover
Low-pass (LP)
High-pass (HP)
10 - 15000 Hz
30 - 250 Hz
Signal-to-Noise Ratio
90 dB
Channel Separation
80 dB
Bass Boost
0 - 10 dB
Bass/Gain Remote
Optional (Accessory required and sold separately)
Fan Cooled
No
Fuse Rating
40A x 3
CEA-2006 Compliant
Yes
Strappable
No
Current Build:
1999 Tahoe #ComingSoon
Previous Build(s):
Crossfire Magnum
5k Pontiac G6 GT
price and the amount of information that can be found is 2
one shows the signal to distortion rating
another doesn't show THD on one amp
BOTH FOUND ON WALMART'S website *cough*
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
the brutus has bigger power and ground inputs and the first one IMO is ugly as hell. I personally would go with the brutus since I've used their mono's and it's cheaper than the first one. I'm pretty sure you could do better with that money though
  • Who's Online   1 Member, 0 Anonymous, 537 Guests (See full list)
