4 1500W amps or 2 3000W amps or 1 6000W amp? pros/cons?
crw092782
I am planning my build and I am to the amp selection. I am going to be running 4 Audioqubed HDC3.0 15's in a wall.
My question is: What are the advantages/disadvantages of running 4 1500W amps vs. 2 3000W amps vs. a single 6000W amp.
Side question: What amp(s) would you suggest?
Corey
2004 Pontiac Vibe Build
Sony MEX-N5000BT
JBL P660C x 2
Sundown Audio Zv4 18
Crescendo BC2000D
Crescendo S800/4
Execution Audio 0 AWG Wire
Sky High Car Audio RCA's
Toolmaker Terminals
XS Power D1200
DC Power 240HP Alternator
Viper 5706
It would depend your goal and what amps really. I mean if you can say use 2 3000watt amps at 2ohms then it could be more efficient then one 6k at 1ohm.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
The subs are going to be D2 so I was pricing out 4 1500W amps and just have each sub to an amp. Then I started to wonder if it would make more sense to do it differently.
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
Miguels, Thanks. I never thought about matching the gains and how much of a pain that would be. I guess I will be looking for a 6k@1ohm amp. Suggestions?
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
Could do a 2 2500bdcp bdsync. Would be spendy though.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Crescendo audio bc5500, ct sounds 4000
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
Look for an amp that will do rated plus then look at average power draw for the amps. I would pick one that has a lower amperage draw and is known for putting out power.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
truthfully.... you will want around 8k for those.... used them, and even in 10 cubes for 2 15s on a 5k, the suspension could keep up, thermally not so much. But i think you will want the extra 2k for the times you need it.
IMO since they are under rated and sq even says put there 2200 on them I would look at the ct sounds 7k or a 8k amp
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
  • Who's Online   0 Members, 0 Anonymous, 868 Guests (See full list)
