KWP123 Posted April 30, 2014 Author Report Posted April 30, 2014 Looks like it could happen. It would be nice if one of the more experienced guys could give it a look over though. Edited: Occasionally im retarded. Now the net volume is only 3.79 after all of the displacements... (subs, port, bracing) so is this the volum that the company is calling for in their recommended volume??? (gross volume or net volume?
timc31610 Posted April 30, 2014 Report Posted April 30, 2014 On FI's site it says 3.5. I don't think the extra will make much difference if anything it should help. As for bracing I would use 1 1/4" wooden dowels. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
Ryan929 Posted May 1, 2014 Report Posted May 1, 2014 Are you trying to keep the back seats? Because I know a guy who has 2 dc 18s on a nendo 5500 in a 4th order. He did have to remove the back seat but it gets crazy loud. Just a thought.
bbeljefe Posted May 1, 2014 Report Posted May 1, 2014 You'd be louder with two 12s in ample volume than with one 15, so unless you just have some sort of obsession with having 15s, I'd seriously consider two 12s. There is more than just cone area to consider in comparing two 12s to 1 15 also. You also have two motors, which equates to more power handling (provided you're comparing similar subs) and most importantly, you'll get a lot better low end extension by giving two smaller subs plenty of internal volume. Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe
KWP123 Posted May 1, 2014 Author Report Posted May 1, 2014 You'd be louder with two 12s in ample volume than with one 15, so unless you just have some sort of obsession with having 15s, I'd seriously consider two 12s. There is more than just cone area to consider in comparing two 12s to 1 15 also. You also have two motors, which equates to more power handling (provided you're comparing similar subs) and most importantly, you'll get a lot better low end extension by giving two smaller subs plenty of internal volume. see if I get two 12's it would have to be from the BL series, which are rated at 1,500rms, so a total of 3000rms I can push. The 15 I want is the SP4 which is rated at 3000rms alone... so no I am not comparing similar subs, so how does this compare out in the end? My end goal is to feel it in my chest. I understand that more cone area means more air moved. But two 12's at 3000rms or one 15 at the same 3000rms. The BL's only have 18mm xmas and the SP4 has 33mm xmas. Plus I have heard that 12's aren't recommended for low low's. I listen to alot of bass boosted dubstep.
bbeljefe Posted May 1, 2014 Report Posted May 1, 2014 You'd be louder with two 12s in ample volume than with one 15, so unless you just have some sort of obsession with having 15s, I'd seriously consider two 12s. There is more than just cone area to consider in comparing two 12s to 1 15 also. You also have two motors, which equates to more power handling (provided you're comparing similar subs) and most importantly, you'll get a lot better low end extension by giving two smaller subs plenty of internal volume. see if I get two 12's it would have to be from the BL series, which are rated at 1,500rms, so a total of 3000rms I can push. The 15 I want is the SP4 which is rated at 3000rms alone... so no I am not comparing similar subs, so how does this compare out in the end? I didn't explain that well. I meant similar with respect to total power handling. With the scenario above, you have more motor force and power handling simply because the two smaller subs will cool better and because both of those models will handle more than their rated power. And with two 12s there is the cone area consideration... 2-12s will give you ~174in² of cone area and 1-15 will have ~123in². THe only other serious consideration is xmax and if there's not much (or any) difference in xmax then the two 12s is definitely a better choice. Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe
KWP123 Posted May 1, 2014 Author Report Posted May 1, 2014 when measuring your port do you measure the longer outside, or the shorter inside lenght for bends
KWP123 Posted May 1, 2014 Author Report Posted May 1, 2014 You'd be louder with two 12s in ample volume than with one 15, so unless you just have some sort of obsession with having 15s, I'd seriously consider two 12s. There is more than just cone area to consider in comparing two 12s to 1 15 also. You also have two motors, which equates to more power handling (provided you're comparing similar subs) and most importantly, you'll get a lot better low end extension by giving two smaller subs plenty of internal volume. see if I get two 12's it would have to be from the BL series, which are rated at 1,500rms, so a total of 3000rms I can push. The 15 I want is the SP4 which is rated at 3000rms alone... so no I am not comparing similar subs, so how does this compare out in the end? I didn't explain that well. I meant similar with respect to total power handling. With the scenario above, you have more motor force and power handling simply because the two smaller subs will cool better and because both of those models will handle more than their rated power. And with two 12s there is the cone area consideration... 2-12s will give you ~174in² of cone area and 1-15 will have ~123in². THe only other serious consideration is xmax and if there's not much (or any) difference in xmax then the two 12s is definitely a better choice. BL's have 18mm and the SP4 has 33mm that is over a cm difference.... is that not conisdered significant enough to make a difference?
DTS909 Posted May 1, 2014 Report Posted May 1, 2014 My BL's get the job done and get low. VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
KWP123 Posted May 1, 2014 Author Report Posted May 1, 2014 Is there a general rule of thumb for how wide a port has to be??? like a minimum it can be before it sounds like shit?
