Power from amplifier
Just a momentary DC offset, most likely.
Shouldn't affect anything once the dc current returns to normal.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
did you replace your radio as well when you installed the rest of the system? if so and if you are still using the factory amp for your speakers you may be giving to much power to the remote turn on lead. many factory systems use 6 volts to turn on and not 12 volts. would explain the poping
nothing, gutted
If the popping is not due to a bad ground. Good chance one of your rca connectors on the amp is (internally) not grounding correctly. It's an easy fix.
truthsayer
  • Who's Online   0 Members, 0 Anonymous, 3493 Guests (See full list)
