Guest MegaloManiac
How to Make your Own RCA: Solder
things you will need:
2 conductor cable(preferably shielded)
RCA ends
heatshrink tubing
heat gun
scissors
wire cutter/stripper
techflex braided loom
Soldering iron
Solder
Blade
Step 1: get your materials
Step 2: Strip your wire (loom if necessary first), that 3rd wire is a shield, it will be twisted together and soldered with negative
Step 3: Get connector "lid" and heatshrink on there before hand if necessary
Step 4: Have connector read to be soldered
Step 5: Tin your connector and wires
Step 6: Solder wire(one conductor goes in center for positive) and the other conductor solder to the ground along with any shield
Step 7: Pull heatshrink forward to terminate end
Step 8: Heat heatshrink so it shrinks up
Step 9: Screw on lid
Guest MegaloManiac
Step 10: Apply heatshrink on lid to "dress" it up some
Step 11: Heat Heat shrink
Step 12: Repeat on other end and you are done!
Very nice bro!
I plan on trying this on some of my next installs. I hate the "curled up under the carpet because it's a little long" look.
Guest Nismofreak
HUH looks good. I might do this for my wires. I say this should be pinned
Guest MegaloManiac
i will be redoing photos, cables do work fine, but the solder joint didnt work out like I hoped. I kinda held the iron on too long and damaged it.
Guest MegaloManiac
many different ways. you can 2 of the same cables and then loom them together or get a 4 conductor wire and use 2 conductors for each connector.
where can these parts be purchased at?
local stores or online stores
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 3996 Guests (See full list)
