2000 Mountaineer Build (from ramming to slamming Part II)(Slowest 15k build)(More limitless goodness)
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
i think it turned out good that amp is pretty heavy and seems super legit compared to that lil arc audio amp that i had was glad i didn't have to rewire or move any fans. had to move over leds but i didn't have to rewire any of them. will probably eventually make 2 bigger led strips to light up the sk 85.4 and maybe add another fan behind it because i have the room.
Looking good Rich.
Sometimes moving the port closer to the hatch will be louder because of port loading. It often lowers port tuning as well. Having it too close can make it worse.
Back in the day had a single 12 in 2 cubes at 30hz and the best score was pretty much dead middle of the cargo area.
Single 18 in 10 cubes at 28hz actually performed best port up.
A lot of it depends on enclosure, tuning, and frequency with these trucks.
Only problem with moving box is that I have to relocate batteries which means bolting them thru the floor. Behind seat and filling in other holes with metal Or epoxy etc. And most importantly redoing grounds in rear because they will not reach..
  • 2 months later...
Sorry that this build has been dead for a while. Haven't really had the time or money to really do anything else to it. Well I blew most of my rts-1 s thinking that I screwed up and crossed them over way to low now have 1 good one on passenger side and one that half works on drivers side. So after researching and not wanting to go super tweeter route I decided on some big silk tweeters. So bought these bad boys off of Madisound under recommendation from jcarter. Also ordered some 12 gauge cca shca speaker wire from droppinhz.com. now just have to figure out where they will fit and glass them in.
That was fast
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
Hells yeah it was came Friday smaller then I imagined heavy little mofos. Thinking they will look like poo in my a pillars have a good idea where to put them in my doors though just have to double check
  • Who's Online   0 Members, 0 Anonymous, 2357 Guests (See full list)
