2000 Mountaineer Build (from ramming to slamming Part II)(Slowest 15k build)(More limitless goodness)
tuning frequency depends a lot on cabin gain and the peak frequency you are looking for, most 4th orders peak around tuning frequency and your car´s resonant frequency is 48 hz so tuning is correct, your problem is the way your cabin acts non walled on a 4th order , is hard to explain but explorers/mountaineers are VERY peaky with that, that´s why i recommended you couple of years ago to do 4 12s non walled or maybe the 6 12s so you could disipate the heat better with more voice coils and power.
I hope that box works for you my man, i know you spent tons of money and time on it!!
Just in case you need it, here´s my loudest 4 12s box in the explorer, car did over 155 @ 45 hz on shitty subs.
Box: 17" Hight (double baffler) x 41" wide x 28" Depth , 3 psp aeroports 6" and full lenght, box should be about 8.5 c/f tuned to 33 hz.
For 6 12s, i would do 20H x 42W x 30D using 4 aeros 6" and 17" long each one
Thanks man for the tips pretty committed to doing this wall unless for some reason my designer has a better idea
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
i´ve always thought this, before doing a wall i need to get LOUD on the cargo area, i had maybe 35 different boxes on the back before actually walling my explorer and most of them sucked ass but it was definitely fun , learned so many things about spl and the explorer itself, worthed every penny!!
For 6 12s you can build a nasty wall for sure, i can give you the max dimensions of that car building the wall outside and slide it inside thru the back
Got this the other day from Droppinhz
Made a big order from Jon rabe at shca audio so think I have everything for my build minus a couple things for the box.
Got more stuff done this weekend box is on hold till design is finished so ran another run of 1/0 shca ofc to the back
And ran wires to turn on and off fans, highs amp, mids amp, sub amps
received_1476424052388926_zpse1qvy4bh.pn
received_1476424359055562_zpsuucegwv1.pn
got some more goodies from mr jon rabe at shca got bonus 2 t shirts on the hookup
so now i will be rockin all shca everything and all smd fuse blocks cant wait to get this slide in wall finished and start hooking up all these goodies
I vote for a slot port between the 2 pairs of triplets. The port will help brace the left & right panels and have 2 small speaker plates instead of 1 large speaker plate.
  • Who's Online   0 Members, 0 Anonymous, 2002 Guests (See full list)
