looking into upgrading to the gtx 760 need some help
alright so i'm looking into upgrading the gtx 760 i wanna make sure it's gonna be compatible with what i have
my current mother board http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
case http://www.newegg.com/Product/Product.aspx?Item=N82E16811144076
power supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016
card i'm interested in
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130932
people who have bought from me Team Bassick (ALPINE) Purplehaze nidus
head unit sony dsx-s310btx
subs 2 12 incriminator audio king of bass
subs amp incriminator audio 20.1
mids/highs
mids/highs amp incriminator audio 6.4
equalizer clarion
crossover interfire
alternator 1 mechman 240amp
battery's xs power 1 d2100 2 d3100
sky high car audio 1/0 awg ofc wires
memphis car audio 1/0 ofc
xs power xs flex 4 awg
sky high car audio 8 gauge ofc
sky high car audio 12 gauge ofc
t spec rca
check out my building log http://www.stevemead...frey-build-log/
http://www.stevemead...d-other-things/
check out audio gear i have for sale
http://www.stevemead...51#entry1595151
i would buy a bigger power supply like 650 or bigger
REP
That card that your interested in is a case+psu combo that is sold out lol
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
The link to the card is borked its for the case not the card. If the 760 your looking at has two power connectors most likely a 8 pin and 6 pin pci-e You will be fine. I'm running a asus dcu 2 oc 760 on a corsair cx500 with a amd 8350 and its fine.
mids/highs
equalizer clarion
crossover interfire
t spec rca
Looks good to me says you need a psu with amps on the 12 volt rail. Your psu has three 12 volt rails each with 22 amps and the card you want use one 8 pin and 0ne 6 pin pci-e. The one thing I cant find out is what connectors on the Psu correspond to each 12 volt rail.
Yeah and the evga site said it needs to be rated at 30 amps
mids/highs
equalizer clarion
crossover interfire
t spec rca
I would never under amperage a power supply, it causes OTHER things to prematurely fail from my understanding. Been doing PC repairs for years, and it's always been the same crapbox PSU I receive from Dell, HP, Gateway, even Sony....
I'd say you need a stronger PSU before you can get that.... Not one with a 30a rail, but give it 5-10 more amps for leeway (sort of like room to breath so you don't stress the PSU out too much).
I've always been a fan of thermaltake's PSUs, not that you should get it, but it's worked out well for me.
I personally own this one : http://www.newegg.com/Product/Product.aspx?Item=N82E16817153106 (which is out of stock now). I haven't purchased a new PSU in a LOOOONG time, and as you can see, the PSU houses a whopping 69a (I believe I paid $45 for it at the time though). which was a steal.
GL either way! I hope this helps.
I've installed that exact Antec 550W PSU into 4 systems built for friends and family and 2 of the systems are running high-end cards with no issues. One has a GTX 670 and one has a Radeon HD 6970. The system with the HD 6970 is also running a 125W Phenom II X4 955BE CPU. Both systems have been up and running for 2+ years without a single issue. You shouldn't need a new power supply to run the GTX 760 in your current system. A 550W PSU is plenty for nearly any system with a single GPU.
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
