2 subs 2 amp wiring help/options 2)AQ3500.1 2)4omh dvc subs
FamilyB4Others
What are options do I have on wiring these together
2) AQ3500.1
2) 4omh dvc subs
Lets say I wire the 2 subs down to 1omh and when its connected to the amp it splits to .5omhs each sub? So If I wired the subs to 4omh the amps(strapped) feeds it 2omh each or 1omh?
If I strap the aq3500.1 its stable at 2omh, meaning it feeds the two subs 1omh each?
sorry if my questions are a bit confusing, it would be more simple over the phone or in person..
basically what I wire the subs down to the amp feeds the correct omhs ?
my goal is to get the most watts
With 2 subs that are Dual 4 ohm coils, on a mono amp like that, your options are to wire to 1 ohm final at the amp, or 4 ohms final at the amp. These are the impedances that the amp "sees".
Since your amp is rated at like 4300W @1 ohm, that's the most power with the current subs that you have.
So I can wire down to 1 omh and strap 2 aq3500.1? I read on here somewhere when you strap it still feeds out 1 omh so I would be ok?
  • Who's Online   1 Member, 0 Anonymous, 1727 Guests (See full list)
