Dehubb Posted May 15, 2014 Report Posted May 15, 2014 I have to make a choice real soon about which pair of subs i want to put in my car. Just looking for some help on the choice i should make. Choices are between: Soundqubed HDC415-D1-A , MTX 9515, & Massive Audio HIPPO 152. They will be installed with a Massive Audio 8000d amp. Soundqube Spec Model HDC415-D1-A Woofer Size 15" Fs 39.03 Hz Vas 31.140 ltrs (1.100 cubic feet) Xmax 40mm Qms 5.204 Qes 0.373 Qts 0.348 Motor Weight 65lbs Coil Diameter 4.0" Coil Length 2.14" Useable Throw 2.75" RMS Power 2000 W Peak Power 6000 W Mounting Depth 8 1/8" Cutout Diameter 13 3/4" Model HDC415-D1-A MTX 9515 Specs RMS Power : 1000W Max Power : 2000W Impedance : 2x4 Ohm Frequency response : 32Hz - 150Hz Sensitivity : 93,80 dB/2,83v/1m Diameter : 38cm (15’’) FS : 31,9Hz Qts : 0,65 Vas : 70,0Liter Xmax : 26mm Depth : 27,3cm Massive Audio Specs Specifications Sensitivity: 97 dB RMS Power Range : 2000 Watts Peak Power Handling: 4000 Watts Impedance: 2 Ohm Diameter: 15 Inch Shallow Mount: No Number of Voice Coils: Dual
Guest Posted May 15, 2014 Report Posted May 15, 2014 single soundqubed hdc4 will be able to soak up the 4k at half ohm.
timc31610 Posted May 17, 2014 Report Posted May 17, 2014 How much space do you have? The hdc will want a pretty big box. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
n8ball2013 Posted May 17, 2014 Report Posted May 17, 2014 No vs threads please THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
