hey i am trying to figure out how big i should go for my sub.
prefab is shit.
i was thinking 4 cubes @ 32hz :unsure:
if i put my sub in a bigger enclosure will it be ok with less power then its rated?
i been keeping my gain way down so i don't distort the vc. cuz i am only pushing about 800rms @ 4ohm
untill i get a 1 ohm stable amp.
Edited by n31l
Fifth Gen Toyota Celica ST
Old system:
Sony Xplod CDX-L550X.
Orion H2
Prefab box. tuned way high
Memphis 16-MC1500D
Lightning Audio B2 3way 6x9's.
Upgraded: ..
Head unit: Eclipse CD5425 5v preamp
Subwoofers: (2) Diamond Audio D6 12's.
Enclosure: 08' Memphis Car Audio enclosure
Amp: DEL Directed Audio 1200t. (class A/B) 2 chan
what size h2?
Head Unit: Pioneer DEH-P4050UB
Subs: 2 Pioneer Premier 12" ts-w3004spls
Sub box: 3.2ft3 tuned to 35hz
Sub Amp: SoundMagus DK 1800
Speaker Amp: Rockford Fosgate 200a4 Bridged to fronts
Front Speakers: DLS MS5A components
2 gauge power & ground
12"
Old system:
Orion H2
Memphis 16-MC1500D
Upgraded: ..
ok thank you. does this look ok
Net Volume: 4.0 cubic feet
Tuning Frequency: 29 Hz
Port Width: 3.5 inches
Port Area: 47.25 Square Inches
Port Length: 32.25 inches
External Dimensions: 34 wide x 15 tall x 22.25 deep
Edited by n31l
Old system:
Orion H2
Memphis 16-MC1500D
Upgraded: ..
also this is my first time doing a t port ive always used aero ports. i always thought areo ports sounded deeper (lower) idk i've read alot on here and that changed my mind. for this sub should i do a slot or areo.
Old system:
Orion H2
Memphis 16-MC1500D
Upgraded: ..
Ive always used aeros as well its easier to change the tuning to your desired frequency, but your specs look good for the slot.
hey man just so you know for that sub i would go with 2.5 cu ft tuned to about 33 or 34 hz. the h2's like smaller boxes. Just something you may want to know. btw, ive been through 9 pairs ( yes that is correct no joke) of h2 12's and i have run them since they first came out. I still run them in the girls daily. If you have any more questions let me know.
sensai
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
Is this for SPL or daily? 4 cubes seems a bit big for a 12'...
For SPL try 2 cubes or less with a 6" aeroport. If it's going in the Celica in your sig you should have a reasonably res. frequency ie. 50+ so tune to that. 29hz tuning, while it will play brutal lows, will give crappy numbers. Especially with a 12".
10.x volts fo' life!
x2 on the tuning. that's kinda low imo. i'd tune to mid to high 30's. if boon says they got a resonance freq of 50 i'd maybe tune to that. or make interchangable ports for both.
  • Who's Online   0 Members, 0 Anonymous, 2083 Guests (See full list)
