Aaron Tuck TBA Posted June 2, 2014 Author Report Posted June 2, 2014 I have Diyma oversized 0 gauge wire throughout. All grounds have been ground down to bare metal for both the big 3 and the amp/rear battery. Like I stated in the first post I have a XS D925 under the hood and a XS D2400 in the trunk. Stock alternator for now looking into a new one. I have a ground from front to rear batt and a ground to the rear strut bolt that I have sanded bare. Everything is tight. I'll monitor voltage at the amp tomorrow. Quote 2000 Cavalier 4 doorXS D925XS D2400XS D31004 runs of 1/0 Mechman 270 2 DD 9515js
CleanSierra Posted June 2, 2014 Report Posted June 2, 2014 You may have an amp that's got a problem then. Quote Im not the one you want to try to troll. Just a fyi for you.
Aaron Tuck TBA Posted June 2, 2014 Author Report Posted June 2, 2014 If it is an issue with the amp I want to test and make sure it's not a fault somewhere else. If it is the amp. Any one you could recommend on repairing? Quote 2000 Cavalier 4 doorXS D925XS D2400XS D31004 runs of 1/0 Mechman 270 2 DD 9515js
CleanSierra Posted June 2, 2014 Report Posted June 2, 2014 DB-r repairs the Sundowns. Quote Im not the one you want to try to troll. Just a fyi for you.
Miguels Posted June 2, 2014 Report Posted June 2, 2014 not enough electrical.. what DMM did you use to tune the amp? Quote my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Aaron Tuck TBA Posted June 2, 2014 Author Report Posted June 2, 2014 It's DMM I purchased at O'Reilly Auto. I figured my electrical should be ok for the amp turned down. I ran my old zx750.1 with a birth sheet rated at 930 wrms in to 2 ohms without the xs power batteries. Quote 2000 Cavalier 4 doorXS D925XS D2400XS D31004 runs of 1/0 Mechman 270 2 DD 9515js
Miguels Posted June 2, 2014 Report Posted June 2, 2014 DMM are not accurate.. i have one from autozone and its was off from the fluke at 2 ohms your electrical could be okay Quote my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
P4killer_ Posted June 2, 2014 Report Posted June 2, 2014 Yea at 2 ohms that amp could do well over 900w.. but notnlikely after rise etc.. Maybe your alt doesmt do much if anything and your slowly pull the batts down while the alt cant keep up and go into low voltage protect after 3 min or so.. Quote Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
Aaron Tuck TBA Posted June 2, 2014 Author Report Posted June 2, 2014 I know the amp can push more than 900 into 2 ohm load. That's just where I have it set. Quote 2000 Cavalier 4 doorXS D925XS D2400XS D31004 runs of 1/0 Mechman 270 2 DD 9515js
sundownz Posted June 2, 2014 Report Posted June 2, 2014 Very common issue with any of our older Zenon made amps is the Stinger RCAs not playing nice with the connectors on the amp -- swap those to a cheap set from wal-mart or similar and try it again. Quote - Jacob Fuller - Owner, Sundown Audio - Sundown Audio on FACEBOOK - Please DO NOT PM ME -- use my email address -- [email protected]
