bassaddiction Posted June 4, 2014 Author Report Posted June 4, 2014 so whats the verdict does the skin effect apply to dc or not. i always thought fine stranded wire had more surface area = high amp ratings thanks for all the answers so far btw i have this stuff called nalox i use for terminating Aluminum cables will that help my copper contentions if i used solid wire from nys salty roads lol
Krakin Posted June 4, 2014 Report Posted June 4, 2014 No, Skin Effect does not exist in DC current. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
bassaddiction Posted June 4, 2014 Author Report Posted June 4, 2014 No, Skin Effect does not exist in DC current. bad ass, now i have to 2/0 everything. only thing now is how to connect it. i guess i can buy bolt on lugs or something like that
STEvil Posted June 4, 2014 Report Posted June 4, 2014 the more pressure you can generate on the connection points the better. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
bassaddiction Posted June 12, 2014 Author Report Posted June 12, 2014 i installed the new ground but i didn't really see any improvement of voltage what should i do now i got a kic 1200 batt in rear stock battery front one run of ofc 0 gauge big 3 im running 1 aq 2200 at 2 ohms lanzar 250.4 rf 850.4 im dropping to 11.8 in front full tilt at 2k rmp
bassaddiction Posted June 13, 2014 Author Report Posted June 13, 2014 ???? any suggestions get new agm battery for front? 2nd run of 1/0 add more battery s in rear
STEvil Posted June 13, 2014 Report Posted June 13, 2014 Check where you did your big3. Might have chosen a poor engine to battery ground point. Also are you running stock alt? If so that is likely the issue. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
