IH8PunkRok's Magnum *Yay New Engine and Tablet Dash*
Fak man sorry about the engine but looks like you got in handled. Dash is gonna be pimp!
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
Have some time to work on my dash again today
Now we are down to the nitty gritty meticulous stuff
There are a few areas that aren't right that needed fixing. You can see quite clearly in this photo the nasty edges around the HU and how the mount steps out at the bottom left of the tablet. Both of these areas are my target for today
First things first I need to square up the bottom corners around the HU in line with the factory line at the top
See how far I need to build the area to bring it back into place?
So i cut the corner pieces out and began sanding
Note also the waves I have on the divider piece between tablet and HU. Those were mainly taken care of through sanding but filler was applied to the low areas
at this point I pulled off the plastidip so I could sand properly
Then I began filling
I used a large amount of filler to extend past where I wanted the body line to be so that I could work it back with the sandpaper and get everything perfect
Currently waiting for it to dry. Be back shortly
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
I am always down to help man but everything is a learning process, figure it all out as I go
After the first round of sanding this is what I ended up with
By comparison it is much better but still some issues
There is a slight curve up right here at the end and it is contacting the HU
This side is much better but could still use a bit more clearance
Hard to see the line on the tablet side but it is much better than before
After round 2 of sanding it seems to fit very well
Now we have the clearance
Tablet side has a slight curve, doesn't seem to affect it at all and once it is painted I'm sure it wont be noticeable
ran out of paint though... boo
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Trying something to keep the tablet in
20140917_183327_zps1789e51b.jpg20140917_184100_zps32ad904f.jpg20140917_193038_zps7387e182.jpg
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   1 Member, 0 Anonymous, 1169 Guests (See full list)
