HDC3 & HDC4 Optimum Enclosure Size
Yes that would work though it would be only an increase of like .2-.3 but its worth a try. Also if you do go that route don't forget to wire the subs in reverse.. So you can try both methods and see what sounds better to you.. How does your current box sound??
it is tuned a lil high for me so im thinking on the outer wall of the port adding a 1" board on the inside to make the port smaller should lower tuning a bit
MEMBER>>Team Pulse Car Audio
97 Z71 sierra
8" jl w0 md 400watt amp and dvd system
2000 malibu
1 18" old style btl, jl audio 1000/1v2 build in progress
My YouTube
100% positive buyer feedback on eBay mmatsjugg306 is my ID there
[topic='http://www.stevemeadedesigns.com/board/topic/148756-dd9515mmatsjugg-feedback/']leave me feedback hear for buying and selling[/topic]
each sub was in a box like this
97 Z71 sierra
2000 malibu
My YouTube
i still have both them boxes too
97 Z71 sierra
2000 malibu
My YouTube
  • 8 months later...
So if I have 2 of the current HDC310s on a 2200.2 it would be
  • HDC310 - 1.5 cube net with 17 sq inch port area per cube - tune between 36-41 hz
or
  • HDC310 - 1.25 cube net with 16 sq inch port area per cube - tune between 36-41 hz
because is this per speaker or for the amp running two speakers? I think I would need 2.50 net cube box and 40 of port.. right?
HU: Pioneer DMH-Z5350BT
Mids & Highs: ML280.3, ML700.3, ML1800.3 Mille Legend Series 3 way
Lows: x3 JL Audio 12TW3 powered by JL Audio RD1500/1
Cable: x2 Skyhigh 0 Gage OFC kits. Skyhigh 8 gage & 16 gage OFC speaker cable
Sound Deadener: 121 sq feet of Skyhigh 120mil
DSP: AudioControl DM 810
Project Build Log
Click here: 2001 Jeep Grand Cherokee SQ Build to see the build progress.
It's per sub. So in your case each sub is getting half of the amps power. So for you it's 1000 per sub meaning a 3 cube box with 48sq in of port
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
  • 5 months later...
I know this is an old post but I just recently ran across it. I have an HDC3 15 d2 single sub powered off an IA 40.1 (first gen) at 1 ohm . the first box I built was around 4.3 cubes net and the port was 31 x 2.25 in. and 19.5 in. long, the new box is right at 3.75 cubes net with a port of 8"x7.5"x23.5" . the original box seems to get louder but has a very narrow freq. range and when it hit low it falls flat on its face, kinda embarrassing , the new box has a lot better range and hits a lot lower and sounds good but not as high of output . the old box is sub up port back, the new box I tried sub and port back, also sub and port up but I think I am going to try sub up port back again with the same box.
my question is will changing the port and sub configuration get me to the output desired or what, just trying to figure the best way to get decent numbers.
05 jeep liberty
80 prs h/u
id xs 65 fronts
ss sp2.654 rears
id q450.4 4ch.
ia 40.1 sub ch.
HDC3 15 D2
group31 agm add on
thanks.
  • 1 year later...
I just found this again. Does anyone know if this info is still good for the current production subs?
Pioneer 80PRS
The strongest of necro bumps ?
I hope it's still valid, because this has been what I've been using for all of my C3/C4 boxes
Yeah it's what I have been using too. I just wanted to make sure it was still good for the ammount of power I want to run.
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 502 Guests (See full list)
