dd9515mmatsjugg Posted September 15, 2014 Report Share Posted September 15, 2014 Yes that would work though it would be only an increase of like .2-.3 but its worth a try. Also if you do go that route don't forget to wire the subs in reverse.. So you can try both methods and see what sounds better to you.. How does your current box sound?? it is tuned a lil high for me so im thinking on the outer wall of the port adding a 1" board on the inside to make the port smaller should lower tuning a bit MEMBER>>Team Pulse Car Audio 97 Z71 sierra 8" jl w0 md 400watt amp and dvd system 2000 malibu 1 18" old style btl, jl audio 1000/1v2 build in progress My YouTube 100% positive buyer feedback on eBay mmatsjugg306 is my ID there [topic='http://www.stevemeadedesigns.com/board/topic/148756-dd9515mmatsjugg-feedback/']leave me feedback hear for buying and selling[/topic] Link to comment Share on other sites More sharing options...
dd9515mmatsjugg Posted September 16, 2014 Report Share Posted September 16, 2014 each sub was in a box like this MEMBER>>Team Pulse Car Audio 97 Z71 sierra 8" jl w0 md 400watt amp and dvd system 2000 malibu 1 18" old style btl, jl audio 1000/1v2 build in progress My YouTube 100% positive buyer feedback on eBay mmatsjugg306 is my ID there [topic='http://www.stevemeadedesigns.com/board/topic/148756-dd9515mmatsjugg-feedback/']leave me feedback hear for buying and selling[/topic] Link to comment Share on other sites More sharing options...
dd9515mmatsjugg Posted September 16, 2014 Report Share Posted September 16, 2014 i still have both them boxes too MEMBER>>Team Pulse Car Audio 97 Z71 sierra 8" jl w0 md 400watt amp and dvd system 2000 malibu 1 18" old style btl, jl audio 1000/1v2 build in progress My YouTube 100% positive buyer feedback on eBay mmatsjugg306 is my ID there [topic='http://www.stevemeadedesigns.com/board/topic/148756-dd9515mmatsjugg-feedback/']leave me feedback hear for buying and selling[/topic] Link to comment Share on other sites More sharing options...
Joseph Chambers Posted June 12, 2015 Report Share Posted June 12, 2015 So if I have 2 of the current HDC310s on a 2200.2 it would be HDC310 - 1.5 cube net with 17 sq inch port area per cube - tune between 36-41 hzor HDC310 - 1.25 cube net with 16 sq inch port area per cube - tune between 36-41 hzbecause is this per speaker or for the amp running two speakers? I think I would need 2.50 net cube box and 40 of port.. right? HU: Pioneer DMH-Z5350BT Mids & Highs: ML280.3, ML700.3, ML1800.3 Mille Legend Series 3 way Lows: x3 JL Audio 12TW3 powered by JL Audio RD1500/1 Cable: x2 Skyhigh 0 Gage OFC kits. Skyhigh 8 gage & 16 gage OFC speaker cable Sound Deadener: 121 sq feet of Skyhigh 120milDSP: AudioControl DM 810 Project Build Log Click here: 2001 Jeep Grand Cherokee SQ Build to see the build progress. Link to comment Share on other sites More sharing options...
Cj Kumz Posted June 12, 2015 Report Share Posted June 12, 2015 It's per sub. So in your case each sub is getting half of the amps power. So for you it's 1000 per sub meaning a 3 cube box with 48sq in of port Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!! Link to comment Share on other sites More sharing options...
Next_Level Posted December 1, 2015 Report Share Posted December 1, 2015 I know this is an old post but I just recently ran across it. I have an HDC3 15 d2 single sub powered off an IA 40.1 (first gen) at 1 ohm . the first box I built was around 4.3 cubes net and the port was 31 x 2.25 in. and 19.5 in. long, the new box is right at 3.75 cubes net with a port of 8"x7.5"x23.5" . the original box seems to get louder but has a very narrow freq. range and when it hit low it falls flat on its face, kinda embarrassing , the new box has a lot better range and hits a lot lower and sounds good but not as high of output . the old box is sub up port back, the new box I tried sub and port back, also sub and port up but I think I am going to try sub up port back again with the same box. my question is will changing the port and sub configuration get me to the output desired or what, just trying to figure the best way to get decent numbers. 05 jeep liberty 80 prs h/u id xs 65 fronts ss sp2.654 rears id q450.4 4ch. ia 40.1 sub ch. HDC3 15 D2 group31 agm add on thanks. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted March 5, 2017 Report Share Posted March 5, 2017 I just found this again. Does anyone know if this info is still good for the current production subs? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
RedFred Posted March 8, 2017 Report Share Posted March 8, 2017 On 3/5/2017 at 0:25 PM, ShadeTreeMechanic said: I just found this again. Does anyone know if this info is still good for the current production subs? The strongest of necro bumps ? I hope it's still valid, because this has been what I've been using for all of my C3/C4 boxes Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted March 8, 2017 Report Share Posted March 8, 2017 Yeah it's what I have been using too. I just wanted to make sure it was still good for the ammount of power I want to run. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
