so i plasti dipped my tailgate and i want to do the bottom half of my car .. my only concern is when i pull the painters tape will the plasti dip separate at the tape or will it stay on it and start peeling all of it when i pull it? Any one know?
I plasti dipped my rear fascia of my car and i used masking tape for the places i didnt want paint to get on. Plasti dip worked good but do not let that paint dry and try pull the masking tape off as plasti dip will peal with the tape. You have to pull the tape right after you apply the paint. SOOO frustrating when you need to do multiple coats.
If you try doing multiple coats without it drying first it looks like poo run marks will start as the paint is to wet and thick. And if the paint dries the paint will come off with the tape
2004 Grand Marquis
AA Mayhem 18
Crescendo 3500d
6.5's AQ Pro Audio
AQ Super Tweets
Image Dynamics 6x9
Soundqubed 125.4
MB Quart 80.4
144.2 db
GONZO
2013 Chrysler 300S
Granite Crystal Metallic Exterior
Inferno Red Interior
5.7 HEMI AWD
LMI Air Hammer Intake
Corsa exhaust
Custom Tune
do your first coat. it should be fairly light. no need to go heavy yet.
Let it dry for ten minutes.
repeat. try to leave the area close to the tape less covered
on your last coat do a full coverage making sure the tape area is completely coated. immediately after spraying begin to peel the tape. be careful to not let your tape hit the freshly dipped area
I've done this many times and it works well
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 1871 Guests (See full list)
