bcbrassard Posted June 6, 2014 Report Posted June 6, 2014 SQ HDS310 under $150 and better than the P3 IMO.
Flamingsword360 Posted June 6, 2014 Author Report Posted June 6, 2014 If its a prefab double check net volume, port area and tuning. Prefabs ate usually off from a small amount to a big amount Its not a prefab and I have checked it and it has 1.50cf net vol.
Joshoe Posted June 7, 2014 Report Posted June 7, 2014 What 10" would you recommend? for say 750rms please under $150 maby soundqubed HDS210? Yes that would be a good choice from what i hear.. But i have no experience with Sounqubed yet i've heard nothing but good from them! I even considered buying a HDC 4.0 over my Zv4.... My opinion with your airspace i would go with 2 8s over 1 10.... Just my 2 cents.
alaskanzx5 Posted June 7, 2014 Report Posted June 7, 2014 Imo single 10 that can move air and likes bigger boxes or a single 12 that likes small boxes. 2 8s in a ported box would (pending what 8s) might need a little more airspace. Something closer to 2cuft and at that you would be in the 12" speaker volume range. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
SMF93 Posted June 7, 2014 Report Posted June 7, 2014 SQ HDS310 under $150 and better than the P3 IMO. So you've heard the hds310 and P3 in person?
alaskanzx5 Posted June 7, 2014 Report Posted June 7, 2014 I'm fairly certain he owns the hds310 and I'm sure he has at least heard p3s. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
