USACi class for Outlaw SPL Myrtle Beach Nopi
BigManAC
Hey guys so im planning on going to a show in July and I want to compete in the Outlaw SPL event which will be my first event. The only problem is im having trouble in understanding what class I would be in so I can register. My system specs are in the description and the system runs at 14.4v.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
It's not more about your equipment, but about your install ...
Voltage - Fine
all aplifiers combined rated at 4 ohms ... best thing to do would be to take out all mids and highs amplifiers and have nothing but sub amplifier(s) ...
Would it be fine if I just disconnected the RCA's from the amp or would I need to disconnect the power and ground wires
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
every amplifier is counted towards your rated power no matter what it is hooked to.
PROPER POWER CLASS:
A competitor may not compete in a power class other than the one that his/her total system power
dictates. The exception to this would be the unlimited or “OPEN” power class
Any and all amplifiers within the vehicle under test will be included in the system’s total power. This sum
will not include the power, if any, of the systems source unit (radio, cassette tape or CD player) unless it
is actively driving a speaker or a group of speakers. All amplifiers in the vehicle must be operational and
actively used in operating the sound system during testing or be physically removed. At local events
amplifiers may be left in the vehicle provided the event director has the ability to definitively determine
the amplifier is not in use.
Competitors whose systems include amplifiers that are not manufacturer rated, are modified internally,
or not commercially available will be required to compete in the unlimited power class of their respective
division.
http://www.soundoff.org/rules/2014splrules.pdf
Kicker
ZXS 1500.1
Solo-Baric S12L72 (2)
ZX 650.4
KSC693 6x9 (4)
PKD1 1/0 AWG
K-Series RCA's
4 AWG Big 3
85 Monte Carlo
Nobody counts highs amps anymore. Even though it's still in the rules. 99.99999999% of judges will just let you unplug the RCA's if they even bother at all.
Just quickly looking at your build log, you're certainly eligible for "Trunk 0-1000". Which is probably the class you would want to run. BUT... you're also eligible to run one of the clamped classes. Those are fun. Run Super Stock 2,000w clamped. Or both clamped and trunk.
You can also run mod or super mod or super port or trunk 1,001+ or stock 0-750 or whatver. You're basically eligible for any class USACi offers except stock 2k clamped because you have an extra battery.
Extra battery? Bc I replaced the stock one under the hood?
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
  • 1 month later...
Alright well I finally got signed up and will be in the SB2 division i believe and plan on running Trunk 0-1000
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
