American Bass DX15 Box Help
Hey guys, I just picked up an AB DX15 for my GF's son and was wondering if anyone had a clue what size box these subs like. Available space is 24"D x 40"W x 24"H going in the back of a 99 Dodge pickup extended cab. He will be powering it with an Alpine MRP-M500 which will only give it 250 watts. I'm looking for loudest possible with decent range. I would guess sub/port up would be our best option as far as placement goes. Thanks for any and all suggestions!
I know it's a miniscule build compared to most but will be his first!
I emailed American Bass and there are no help. I was able to get the ts specs from their website but when I input it into winisd it gives me an error saying missing parameters. WinisdError_zpsdeb5b7b1.jpg I have tried numerous times and can't figure it out.
Here are the specs:
Impedence (Ohm) 4
Rdc (Ohm) 3.5
Levc mH 3.783
Fo Hz 30.4
Sd msqM 76.45
BL TM 16.295
Qms 4.764
Qes 0.635
Qts 0.56
n% 0.375
SPL dB 89.8
Vas L 89.6
Cms uM/N 105.6
Mms g 259.6
VC Inch 2.5
Mgnt oz 120
Xmax ±MM 15
RMS 500W
MAX 1000W
F.Range Hz <500
Mounting Depth
MM 228
Inch 9
SPK DISP. L 6.824
Thanks again for the help!
I would say 2.5net 12 sq.inches of port per cube @ 35hz 500rms. Or 3 cubes with 12sq.inch per cube at 250rms. 4 cubes with 50sq inches of port is probably wayyyy to much for that sub judging by the weak motor force and lack of mechanical excursion.
Thanks guys, Joe I thought Winisd was ok for modeling in a car environment. If not is there a better way?
Slowfkncar, thanks man, Ill go between the two recommendations since he will be starting at 250 and moving up to 500 eventually.
  • Who's Online   0 Members, 0 Anonymous, 1559 Guests (See full list)
