Well that was a sh**ty run
Rck'nRF
Do some more reading on the subject of setting gains. After that and only after that come back and let us know why you blew your sub.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
My HU is a pioneer 45wattx4(15wx4 RMS) and when i had my Rockford
gain ANYWHERE UNDER 3/4 it was ABSOLUTLY unacceptable! as for producing bass,
No matter where i adjusted bass/settings on headunit,amp/X-over,there was NO
cab filling bass a 15" should be doing. This is the 1st sub i ever burned out
,and if my gain was to high then
i'm "glad i cooked it" ..
Pioneer makes a lot of different head units and the internal amp has nothing to do with the preamp voltage. If your head unit has a 4 volt preamp the gain was set way too high and if it has a 2 volt preamp, it was still too high.
The gain knob is not supposed to make up for a lack of power, a poorly constructed box or a cheap sub. It's there to match the signal strenth from the preamp to the sensitivity of the amplifier. Nothing more and nothing less.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
I think a smallish sealed box (1.5cuft)really aided in a nicely cooked coil also,
I do know this one is going ported from hence forth,i have a new respect for moving/cooling air..
i know i have the ears of a bat when it comes to how music should sound,and where i had my gain
was perfect,if a sine wave killed it,good riddance,but i sure did love the look of the "S" Alpine series!
Well,today i am throwing in my 2Ohm "S" alpine 15" into the same box,going to adjust this previously &
heavily used sub to my ear again..will post conclusions&results for you in the weeks to come for
the exciting results! (burned out sub was 4Ohm'r)
With a smaller sealed box you should be able to put a little more power to them than a large ported box. Bro-ski, it's your fault man. Plus 1.5 cu ft. is a bit big for an alpine type s.
Straight from Alpine itself:
"•sealed box volume: 1.32-2.07 cu. ft."
Box volume had nothing to do with what a voice coil can handle thermally.
Your ear cannot hear a square wave, period. You set your gain by ear, that's the likely reason the coil likely gave up. It probably died from an improperly set gain, nothing more, nothing less.
The other possibility is that the sub had a defect from the factory and went prematurely. There are literally thousands of Type S setups around the world that likely have gains set the same way yours was, as are still alive today.
  • Who's Online   0 Members, 0 Anonymous, 3326 Guests (See full list)
