hutt132 Posted June 8, 2014 Report Posted June 8, 2014 I bought a BK1800.1D amplifier and ONLY hooked up with 0 gauge power wires and the remote turn on wire. The positive wire is hooked straight to the battery with a 150amp fuse, and the negative wire is about two feet long and bolted to a stock bolt in the trunk. I sanded down the paint before attaching it. For the remote wire I have an Add-A-Fuse plugged into fuse #32 in my 2006 Acura TL with a 20amp fuse in the top slot, and a 7.5amp fuse in the bottom slot.When I turn on my car the amp powers on and goes into protect for a few seconds, then out of protect for a few seconds, and continues this. I then connected the positive on the amp directly to the remote power on. Same thing as above. Is my amp bad? Did I do something wrong?
SnowDrifter Posted June 8, 2014 Report Posted June 8, 2014 To confirm:Amp protects with no RCAs and no speakers hooked up? Do you have a multimeter? Confirm voltage at the amp terminals with the car off, and car on - both in protect and just before ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
hutt132 Posted June 8, 2014 Author Report Posted June 8, 2014 To confirm: Amp protects with no RCAs and no speakers hooked up? Do you have a multimeter? Confirm voltage at the amp terminals with the car off, and car on - both in protect and just before Amp protects with no RCAs and no speakers hooked up. When the car was on the voltage of the power terminals at the amp was 12 and the remote turn on 11, when it was in and was not in protect. I didn't have a multimeter with me that could read decimals.
hutt132 Posted June 8, 2014 Author Report Posted June 8, 2014 Should the AMP turn on properly when it only has power and remote wire hooked up? My friend can't get over the fact that it's only going into protect because the RCA and Speaker wires are not connected... Even though I tried with those connected, too.
n8ball2013 Posted June 8, 2014 Report Posted June 8, 2014 It should power up with just power remote and ground. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
BigManAC Posted June 8, 2014 Report Posted June 8, 2014 So with your car running the amp is only seeing 12v? If the car is running it should be seeing in excess of 13v or more 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
truthsayer Posted June 8, 2014 Report Posted June 8, 2014 Just out of curiosity, is your amps gain cranked up? truthsayer
hutt132 Posted June 8, 2014 Author Report Posted June 8, 2014 Just out of curiosity, is your amps gain cranked up? It is not.
hutt132 Posted June 8, 2014 Author Report Posted June 8, 2014 So with your car running the amp is only seeing 12v? If the car is running it should be seeing in excess of 13v or more I found another multimeter and when the car is on it measured 14v, both when it was and was not in protect.
SnowDrifter Posted June 9, 2014 Report Posted June 9, 2014 With nothing else but power/remote hooked up to it, going into protect, with good voltage at both power inputs and remote wire, the only thing I could conclude is a bad amp ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
