Jwills Posted March 20, 2008 Report Posted March 20, 2008 Hey i need help building a box for 1 18" BTL. I'm running it with a SAZ-3000. I drive a 2003 Hyundai Tiburon GT(hatch). The the dimensions of my car are 36w, 34L, and 18.5H. I do plan on competing in SPL and listening to music. FI advises 5-8 cubic feet and I don't think I can fit 8 cubic feet in my small trunk. Thanks for any help you can give me.
sean 371 Posted March 20, 2008 Report Posted March 20, 2008 Hey i need help building a box for 1 18" BTL. I'm running it with a SAZ-3000. I drive a 2003 Hyundai Tiburon GT(hatch). The the dimensions of my car are 36w, 34L, and 18.5H. I do plan on competing in SPL and listening to music. FI advises 5-8 cubic feet and I don't think I can fit 8 cubic feet in my small trunk. Thanks for any help you can give me. 5.5-6 cubic feet, swappable ports A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
Torres Posted March 20, 2008 Report Posted March 20, 2008 yeah i was thinkin 5-5.5. x2 on the swappable ports for competing. one sec i'll see what i can come up with
AI James Posted March 20, 2008 Report Posted March 20, 2008 what cars this going in, because i can see issues building that big of box then putting it in
Torres Posted March 20, 2008 Report Posted March 20, 2008 what cars this going in, because i can see issues building that big of box then putting it inI drive a 2003 Hyundai Tiburon GT(hatch). actually...those dimensions you gave give you 9 cubes of air after displacement . but yeah this is what i'd do: box: (outer dimensions) heighth = 16.5 width = 36 depth = 21.5 port: (inner dimensions) heighth = 5 width = 7 length = 10 this port will tune the box to about 34.67 hz which is what i personally like to tune mine to. after port displacement...this will give you about 5.27 cubes of air. so you have room to brace it and not go below the recommended volume. this is also assuming that you're using 3/4 MDF. competition port: (inner dimensions) heighth = 5 width = 9 length = 5 this port will tune the box to about 46.21 hz for comps. you can add to the width if you wanna tune higher, or take away to tune a little lower. after port displacement...this will give you about 5.39 cubes of air box should fit snug width-wise if cut right
Jwills Posted March 20, 2008 Author Report Posted March 20, 2008 Ya i can build the box in the car if i need to so that i avoid the problem with putting the box in.
Jwills Posted March 21, 2008 Author Report Posted March 21, 2008 Sounds loud! When you starting it? I will be starting in like 2 weeks... I just ordered all of the stuff so it will take a while for it to all get here
Jwills Posted March 23, 2008 Author Report Posted March 23, 2008 I was wondering will 5.27 cubes be enough or should I do a box with like 6. Thanks for your ideas
