I want to get new subs for my car. I have decided between these subs. The alpine type r 12 and the sundown sa 12. I will be getting the 2 ohm model and 2 subs. The alpine type r is 1000watts rms but a sa12 is only 600 rms. I want the louder subs. So would 2 type rs at 2000watts rms be louder than 2 sa12s at 1200watts rms???? I've seen videos on YouTube that people push the sa 12 over 1000 watts rms. I would be using my subs daily so if I got the sa 12s would I be able to give them 1000 watts each and have them not blow up?? For the amp I would get a Hifonics x2200.1 d 950watts @4ohms this amp has 2 channels so I would wire one sub to 4ohms then connect it to one channel then the same with the other sub. <---- would this work????? Money isn't a issue and I can afford both of the subs and amp. I just want the louder subs with good sound quality. Also I want the ones that would produce louder lows(don't have room for 15s)
Edited by Nick4029
2011 Chrysler 200s
Sundown zv4 12 rev2
2.75ft3 box tuned 32hertz
Hifonics brx 2400
Sky High 1/0 ofc power and ground wire
Sky High 8 gauge ofc speaker wire
Focal auditor 5 1/4 front component speakers
Focal integration 6x9 rear deck speakers
Stock 160amp alt
Welcome to the forum, Nick. :) And as for the question, just in case you didn't know, we are not allow to discuss about "This vs that" subwoofers. Reason: People who love "this" subwoofer will tell you to get it while other who love "that" subwoofer will tell you to get it. Generally-speaking, there is no wrong answers and it's good for a person to experience themselves and see/hear which subwoofer(s) they prefer to. When it comes to the question of "Which one is louder?", please bear in mind that it's all about installation. The type of box and proper/well-built can make a huge difference. You said you do not have an issue with budget. Maybe flip a coin and get the subwoofer. Don't like? You can always sell it and get a different one. Based on what I've seen on Internet and reviews, there are plenty of people who really like/love Alpine Type R and Sundown. It seems to me that Sundown is very good company and well-known for getting extremely loud. That's all I know. Maybe someone in here will help you with it. Good luck. :)
I'm pretty new to the site, so I wasn't FULLY aware of the no VS threads, but I can understand it, I've seen many get ugly real fast, not just on car audio forums, but any forum.
I've unfortunately only seen/heard one sundown in my life and it was an 8" SA series. It was a wickedly loud little beast and seemed to retain much clarity if I recall, but it's been 4-5 years since I heard it, many subs have been heard since.
Alpine on the other hand I've heard numerous Type-R setups, just none of their current 1k line.
"I" wouldn't push my luck on seeing ow long the Sundowns take 2K, I can't help but believe their life would be dramatically shortened if fed such regularly. Granted, if the gain were set for 2K with the amp, chances are rare the subs would ever see the full 2K and even if they did, it's be quite rare. Alpine's Type-Rs have earned a similar rep for taking abuse and I've known many to last quite a while under such conditions.
Alpine is mainstream, while Sundown isn't so much. Chances are there's a larger following for Sundown on Audio forums such as this, but again, that's getting into hot water.
May want to use WinISD and plot both of the subs. It's not a clear indication on which will be louder, but it can give you insight into which is likely to be louder.
Both are sure to be more than capable of playing loud enough to cause permanent hearing damage/loss and get you sound ordinance violations, so...
As said though, a large factor is going to be the enclosure used. Just how much room have you for the enclosure? Loud deep lows tends to take large ported enclosures tuned low.
Oh, and your amplifier doesn't have two channels, it's a mono amplifier with two sets of speaker terminals wire in parallel internally. Wiring as you say, you will have each sub wired with it's coils in series for a 4 ohm load and with both wired to the amplifier, it's see a 2 ohm load and be capable of producing around 1600RMS. That's fine for the Sundown subs, but for the Alpines rated at 1K each, you'd want to opt for the DVC 4 ohm models and wire them in parallel/parallel for a 1 ohm final impedance.
And then since you have said the money isn't an issue, perhaps you can somehow find a way to swing for a "better" amplifier, perhaps something like a Soundqubed Q1-2200D which is sure to produce every bit of 2k and then some.
Edited by Weigel21
No vs threads please
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
This topic is now closed to further replies.
  • Who's Online   0 Members, 0 Anonymous, 1070 Guests (See full list)
