luism1983 Posted June 19, 2014 Author Report Posted June 19, 2014 Is the same width as this box so I can make some smaller boxes on the side and connect them to the main box for a little more airspace audio fanatic
CleanSierra Posted June 19, 2014 Report Posted June 19, 2014 What? This last post of yours confused me about adding smaller boxes and connecting them to airspace... Im not the one you want to try to troll. Just a fyi for you.
luism1983 Posted June 19, 2014 Author Report Posted June 19, 2014 What? This last post of yours confused me about adding smaller boxes and connecting them to airspace... audio fanatic
dolarbilz Posted June 19, 2014 Report Posted June 19, 2014 Lol fail.its more than adding on boxes to a existing box.
Joe X Posted June 19, 2014 Report Posted June 19, 2014 OP if you don't want an external port, this is the sort of layout you can do: Or even this:
luism1983 Posted June 19, 2014 Author Report Posted June 19, 2014 OP if you don't want an external port, this is the sort of layout you can do: Or even this: Those are some nice designs , I went small due to limited space room for groceries got 3 kids, I am gonna go ahead and finish as it is now if I don't like the way it fits or sounds, I am just gonna go with 2 subs 1 amp audio fanatic
Joe X Posted June 19, 2014 Report Posted June 19, 2014 Reverse mount all 4 subs and you would be tuned to 36Hz (more adequate for daily use), furthermore, you could tweak the port to either tune lower or reduce it's size. You could even build a chamber below the box to create a labyrinth port there (that would take some work though).
luism1983 Posted June 19, 2014 Author Report Posted June 19, 2014 Reverse mount all 4 subs and you would be tuned to 36Hz (more adequate for daily use), furthermore, you could tweak the port to either tune lower or reduce it's size. You could even build a chamber below the box to create a labyrinth port there (that would take some work though). I am gonna reverse mount 2 of the subs for sure , but if I do all 4 it would be pointless to have that window, why would the smaller boxes on the side work? I have seen them done before audio fanatic
CleanSierra Posted June 19, 2014 Report Posted June 19, 2014 You're asking for help and advice and you're getting it. You're not liking the advice you're receiving and you're not wanting to take it. You asked,"What do you think of this speaker enclosure?". We answered about what we thought suggestions to fix it. Build it how you want. You should have designed it right before ever cutting the wood in the first place. It doesn't seem like you need any help though, your going to do what you want because no matter what we will say, you've seen it done such and such ways before. Good luck with your build. Im not the one you want to try to troll. Just a fyi for you.
_paralyzed_ Posted June 19, 2014 Report Posted June 19, 2014 I would just pull the port and seal the port hole. Run it sealed. Since it isn't screwed and glued yet, you could cut 3 1/2 inches off the height of the box and that will remove the proper amount of airspace. (I did the calculation)
