Rockford enclosure DIY
Any help is appreciated. I want to run 3 12'' Rockford Fosgate P3D2's, with the RF p500bd1 (birth cert. says 750w rms) for each sub. I need help with the design, volume, vent volume, etc.. I have years of carpentry skills, so building is the easy part.....
i would go 3 cubic feet per woofer. i have no idea what music you listen to so tuning is a mystery. The more we know the faster we can help. what kind of space do you got to work with? why 3 woofers? what music do you mainly listen to?
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
I listen to alot of everything, mainly edm, rap, and heavy metal. I have just under 45 inches in between the rear wheel wells (this is a 2005 ford exploder). Plenty of room for height and plenty of room from the rear seat to the rear hatch. IDk why, just figured I already had 2 12s, why not one more since I have the space.
I would go for 3cuft net per and 100-150" of port area. Subs up port back double baffle with say some bracing. If you can an octo port could look killer in this setup.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, port clearance 4", figure is just an assembly guide:
joe x is the shit
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
joe x is the shit
Hell yea, now we all need to know who is this X who designs great boxes for free. Mystery man? Keep up the good work JoeX.
Whats the alaskanzx5 about?
I made a mistake. For some reason I thought you said 15" subs. My bad.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 3159 Guests (See full list)
