RE Audio XXX 12 in a 4th order
lightfoot
I'm looking for some advice on a design for a single RE Audio 12 XXX in a 4th order bandpass. I have talked to one of the guys at RE and he suggested to make each chamber (ported & sealed) 5.5ft. with 30 sq." of port X 7.5" long. That would be tuned @ 35hz, and peak between 40-45hz.. This sounds completely ridiculous to me (WAY TO BIG). Here are the T/S parameters:
Qes - 0.46
Qms - 3.29
Qts - 0.404
Fs - 21.00hz
Vas - 74.0 liters
Xmax - 54mm
Efficiency-SPL 1W/1M - 83.76 dB SPL
Sd - 480 cm^2
Re - 4.2 ohm
Bl - 18.16
Oh yeah the recommended enclosures are: Sealed 1.1 and Ported 2.2 @ 34hz
Any advice would be greatly appreciated. Currently I have it in a vented box that is 3.3 ft. it sounds good, i'm just looking at a bandpass design so i can port it through the rear deck.
The vehicle is a '05 Nissan Altima and the power I'am running is a BAMF 5500 (I know shitty amp)
Tune it more like 44 not 34 lol 34 is just dumb
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
I just did a bandpass for a Rockford Fosgate P2 and it's only got like 12MM of Xmax. I gave more port to that 10" than you're thinking of giving a sub with 54MM of Xmax. Unless you're considering at least doubling, or tripling port area, don't bother with a bandpass enclosure.
And the guy you talked to, who suggested 30" of vent for a sub that has 54MM of Xmax, he doesn't sound like he knows his ass from a hole in the ground.
i agree 100%. I think we was in the sells dept. or something cause he said in tech support guy was busy doing a build. But anyways what do you think as far as enclosure design?
Honestly, I'm not sure what I'd do for a design for that sub. It will be a big box though, and tuning will be a nightmare if you give proper port area.
is it the newer XXX? my brother has one and it dont like the abuse. they dont take a lot of power to get smelly. we tested a SMD sub in the same box same power and sounded a lot better louder and made more flex... if its the newer xxx do not over power it
  • Who's Online   0 Members, 0 Anonymous, 2930 Guests (See full list)
