Information on 3 different enclosures
LT.Smoke
I am looking to do a rebuild soon and was trying to gain some input on advatages/disadvantages of
Custom Slot port
4th order
6th order
Any info on the differences etc would be awesome thanks
Team MaxRetribution
Si Vis Pacem Parabellum
type of subs really matter when talking 4th and 6th order. so does size of the subs due to space requirments.
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
I am rebuilding to have a musical demo monster.. I want it to move a lot of air from the 20's to 60hz range... Or something close I want it to play low with authority and choke you in the midrange
Team MaxRetribution
Considering level 5 12's
Team MaxRetribution
Bump
Team MaxRetribution
Level 5s do 6th unless u ain't for enough space then do ported
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
6th's are hard as hell to get right. They have a steeper rolloff on both ends than a 4th order. But that doesn't matter a whole lot for us.
4th is 24db/oct and I think 6th is 36db/oct, someone correct me if I'm wrong.
Enclosure can be decided on once you got subs picked out. High qts woofers will prefer 4th order. Low qts will prefer ported/6th. Woofers with a qts of around ~.5 will be happy in whatever.
6th orders will typically have less power handling, it's gonna make those fuckers move.
Slot ports are pretty easy to design, in comparison. 4th's are a little tougher but still not too bad.
Wasn't a rhyme or reason to my post, was just spewing some general shit I knew. Ask some specific questions and I can give you a better idea most likely.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
I am trying to do this in my impala but that is subject to change depending on how long it holds out she is getting up there in mileage
Team MaxRetribution
  • Who's Online   0 Members, 0 Anonymous, 9668 Guests (See full list)
