TRON Posted June 25, 2014 Report Share Posted June 25, 2014 I don't think daisy chaining is the same as strapping. You have (4) dual 4s, so what you should do is run two in parallel parallel on one amplifier (coils in par. and drivers in par.) which would give 1 ohm on one amplifier, and do the same with the second amplifier. You'll need a tool to set up both amplifiers to output the same. Make sense? EDIT: Do this on each amplifier. Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s Link to comment Share on other sites More sharing options...
Karkov Posted June 25, 2014 Report Share Posted June 25, 2014 Just running multiple sub amps without strapping? I.E. pass thru and slave/slave/slave etc.? 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0 Link to comment Share on other sites More sharing options...
MrSkippyJ Posted June 25, 2014 Report Share Posted June 25, 2014 So daisy chaining is running amps seperately? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Karkov Posted June 25, 2014 Report Share Posted June 25, 2014 So daisy chaining is running amps seperately? I don't know man, I am asking as well, I am also making assumptions as we speak, lmao! 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0 Link to comment Share on other sites More sharing options...
TRON Posted June 25, 2014 Report Share Posted June 25, 2014 So daisy chaining is running amps seperately? Pretty sure its just running an amplifier off of the pass through of another. Meade has a video of setting up daisy chained amps I think. Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s Link to comment Share on other sites More sharing options...
MrSkippyJ Posted June 25, 2014 Report Share Posted June 25, 2014 I see. RCA from headunit into first sub amp, then RCA output from that amp is the input for the second amp? In that case daisy chaining has no effect on impedance. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
tacomaguy1 Posted June 25, 2014 Report Share Posted June 25, 2014 ^ that Wasn't sure what he meant, some people interchange the terms Daisy chain you'll need to gain match the amps Team Flex Issues Link to comment Share on other sites More sharing options...
TRON Posted June 25, 2014 Report Share Posted June 25, 2014 Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s Link to comment Share on other sites More sharing options...
nvarano Posted June 25, 2014 Author Report Share Posted June 25, 2014 Owner of a local shop I talked to a couple hours ago said if I daisy chained "or strapped pick which one you want" my amps each running at one ohm would have an end total impedance of 2ohms. Which is what I would want in order to wire four dvc 4ohm subs. Link to comment Share on other sites More sharing options...
nvarano Posted June 25, 2014 Author Report Share Posted June 25, 2014 The terms daisy chain and strap can be interchanged, different manufacturers and distributors, I have found, use either term depending on what side of the bed they woke up on Link to comment Share on other sites More sharing options...
