daisy chain help
nvarano
I don't think daisy chaining is the same as strapping.
You have (4) dual 4s, so what you should do is run two in parallel parallel on one amplifier (coils in par. and drivers in par.) which would give 1 ohm on one amplifier, and do the same with the second amplifier. You'll need a tool to set up both amplifiers to output the same.
Make sense?
EDIT: Do this on each amplifier.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Just running multiple sub amps without strapping? I.E. pass thru and slave/slave/slave etc.?
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
So daisy chaining is running amps seperately?
I don't know man, I am asking as well, I am also making assumptions as we speak, lmao!
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Pretty sure its just running an amplifier off of the pass through of another. Meade has a video of setting up daisy chained amps I think.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
I see. RCA from headunit into first sub amp, then RCA output from that amp is the input for the second amp? In that case daisy chaining has no effect on impedance.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Owner of a local shop I talked to a couple hours ago said if I daisy chained "or strapped pick which one you want" my amps each running at one ohm would have an end total impedance of 2ohms. Which is what I would want in order to wire four dvc 4ohm subs.
