Going For 10,000 Watts Rms
bassmachine
Alright. well if your serious about higher voltage and needing 10k then I recommend bumpin on up to 16volts and run a pair of Sundown 3000s. They'll do 5k each @ 16volts and be much nicer on your electrical than any maaudio amplifier.
x2.
I would just make sure you get good equipment from the get-go, instead of having to change things out later on.
tejcurrent
XS Power
T3
well hell i might as well stick to my massives at 15volts its 5000 watts on a 2ohm load. :)
Windows Xp1 40 & 120gigHDDMSI BoardUNDERCONSTRUCTION Dr. Doom aka StarScream3kDestruction at ur service
no sir i want to go 20,000watts, 4 massives on each sub at 15volts stable.
ok, here are my thoughts.
1. if you are wanting to run 20k watts, dont try to do it with lower level amps.
2. if you are seriously wanting to put all this in a camary, you better look into beefier suspensions.
3. there is no way in hell you are going to fit 4 200 amp alts. in a camary...so I would suggest finding another car first...and by car I mean SUV.
I hope you are able to pull off a 20k watt system, but I seriously think you are underestimating what it is going to take.
My System:
Pioneer AVH-P3200BT
4-Dayton 7 inch reference series (front doors)
8-Onkyo 3/4 inch tweeters (dash)
1-Sundown Audio 100.4D (mids/highs)
2-18" BTL's (for now)
Crescendo 3kwp (for sale)
Complete rebuild coming soon...
I hear you but its something noones never done and i know i can do, I have a Large gap in my enginge ive tested n measured my friend, and suspension is already covered.
:blink: Is this a joke?
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
I actually wanna see him pull it off....doubt it will happen... but wouldn't mind seeing him try
1998 Toyota Camry XLE V6Goldwood GW-S650/4 6.5sEA 200a alt2009 Lancer GTSStock jtte2o.gif
and fail miserably
4 15s in a camry... 4 alts HA i dont think so bro might wanna measure again
PIerce audio moab 15s wont handle that power at all what so ever :lol:
I wouldn't so much doubt fitting the subs/amps/batts/alts/highs with a very skilled installer, but what other installs have you done, major modifications? Are you familiar with suspension components and air ride? Can you weld?? I wouldn't attempt this kind of a install without fairly extensive knowledge of cars and fabrication.
Like 01xtreme said I think your underestimating and really aren't sure what your getting into..
  • Who's Online   0 Members, 0 Anonymous, 10055 Guests (See full list)
