ok that sounds good, what about glue and more screws on the middle of the roof for example?wouldn´t the wood take the shape of the roof? once again, haven´t done this thing before, just stealing op´s topic instead of starting a new one
Where would the screws attach...go through the roof?
Maybe if its thin wood it might conform
believe it or not, i was actually thinking about going trough the roof and just cut those things on top of the room, fixing that and then painting roof with bedliner or something, my roof already has tons of holes and cracks because of the bass lol
First I welded steel ribs to the roof which caused bubbling on the roof that had to be sanded down and repainted. But from the frame you could easily lay sheets down (wood or metal your choice) mad then foam. But when I planned out my rebuild I needed every bit of air space I could muster and scratched that idea. I was going for extreme rigidity but then at some point I realized 0 flex is impossible when you're loud, lol
i´m not loud as you were so it´s cool lol, how much should i gain by reinforcing the roof like you did?
use multiple thinner layers so it bends. i used 1/2" on the roof lots of glue and lots of foam.
if your not worried about holes in the roof... just use carrage bolts. but youll still want thin layers so you dont suck the roof down. ( you want the wood to bend to the shape of roof, not the roof to bend to wood)
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
awesome man, sounds like a good plan! and no, i don´t care about the holes since it´s not my daily drive and it actually looks like crap already lmao
BTW, what about using 3/4" mdf and just kerf it so it takes the roof shape? would it work?
Kerfing now that is not a bad idea. I'm still trying to figure out how to place the jack lol. That's my only issue. Don't wanna break my center console.
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
  • Who's Online   0 Members, 0 Anonymous, 2486 Guests (See full list)
