Joe X Posted July 5, 2014 Report Share Posted July 5, 2014 OP I see in one of your pics the port parts assembled in a different way than the figure and cutsheet provided specified, I just want to be clear that is not by mistake, to be clear, the port needs to be 5 1/8" wide everywhere or it won't work as intended. Link to comment Share on other sites More sharing options...
dharris2488 Posted July 5, 2014 Author Report Share Posted July 5, 2014 OP I see in one of your pics the port parts assembled in a different way than the figure and cutsheet provided specified, I just want to be clear that is not by mistake, to be clear, the port needs to be 5 1/8" wide everywhere or it won't work as intended. Joe X, the port opening is 5 1/8" wide, except in the corners. I meant to ask you if I should 45 those at 5 1/8"? Is that what you mean? If you are asking if my port is 5 1/8" throughout the full length, then yes it is. It's just not flared on the opening and there are no 45's. Both those can still be completed.... Please advise. Thanks! 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere Link to comment Share on other sites More sharing options...
dharris2488 Posted July 5, 2014 Author Report Share Posted July 5, 2014 Oh yeah, I remember something was up with my front baffle. It was 3/4" too wide and I went ahead and cut it off. I cut and measured all pieces as stated on the cut list and couldn't figure out why the wide baffle was 3/4" too long. I did however measure the port from opening and all the way to the end and it kept a 5 1/8" width all the way through length of the port. I was stumped and decided to cut it off. I can snap some pictures with a measure to show you the width down the length of the port, if you want that is... 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere Link to comment Share on other sites More sharing options...
dharris2488 Posted July 5, 2014 Author Report Share Posted July 5, 2014 When I was trying to figure out what was wrong, I decided to figure out what the net volume was. When I calculated it out, I came up with 3.75 before driver displacement and bracing... I figured all was good, as the port width stayed the same... That's when I cut the extra 3/4" off the front baffle. 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere Link to comment Share on other sites More sharing options...
Joe X Posted July 6, 2014 Report Share Posted July 6, 2014 If the external dimensions are the same and the port is 5 1/8" all the way through (obviously the turns are wider) and you do that double layer baffle I guess you are ok, build this box extremely strong. Link to comment Share on other sites More sharing options...
dharris2488 Posted July 6, 2014 Author Report Share Posted July 6, 2014 Yes, everything checked out ok. That's why i was stumped... I just chalked it up to a computer glitch? IDK? But yes, port width is actually the best i've ever done, and all the externals check out ok. I used Gorilla Wood Glue to glue the two baffles together and then used LockTite P3 for the adhesion of the two baffles onto the enclosure itself. I then put plenty of screws down. I plan on putting a dowel rod from front to back as soon as I get the holes cut. Thought about fiberglassing, but we shall see. Thanks for your help, design and input. Always much appreciated... 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere Link to comment Share on other sites More sharing options...
dharris2488 Posted July 6, 2014 Author Report Share Posted July 6, 2014 If the external dimensions are the same and the port is 5 1/8" all the way through (obviously the turns are wider) and you do that double layer baffle I guess you are ok, build this box extremely strong. Should I 45 the turns? Or leave them be? 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere Link to comment Share on other sites More sharing options...
dharris2488 Posted July 14, 2014 Author Report Share Posted July 14, 2014 Ok guys, I have video uploading now. Here is one, but I have better on the way. (2) 12" Ethos on strapped Q2200's. THanks Joe X for the box design. Not sure how the cut list was off, but the enclosure sounds great! Here is a short video and please keep in mind, i'm no director! lol Also, in the next video I post, it will actually show the subs and amps, but please keep in mind that I'm not finished with the cosmetics. I finally finished the sound portion of this build, now on to the cosmetics! Here is a little teaser... http://youtu.be/OYYKmYUBP1E 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere Link to comment Share on other sites More sharing options...
SMF93 Posted July 14, 2014 Report Share Posted July 14, 2014 Nice! Link to comment Share on other sites More sharing options...
dharris2488 Posted July 14, 2014 Author Report Share Posted July 14, 2014 Here is another video of the build. A little longer, but not edited at all. I just wanted to post it and be done with it. Hope you guys enjoy the shakiness and amateur video! lol. Here you go, video #2... http://youtu.be/IYQDlyGgHxU 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere Link to comment Share on other sites More sharing options...
