cole00c7r Posted February 4, 2015 Author Report Posted February 4, 2015 After taking everything out and securing the wire I had already been working thru the night and into the next day. Who sleeps when they could be working on there ride! Here is the engine bay all finished for now, dont mind the dust/grime im gonna clean that up when it isint as cold! Anyway here are some pictures of the assembly of the interior, I got almost all of the process but then my phone ran out of juice and got tired haha. Annnddd....thats all I got, I thought I got more pictures putting everything back in, but oh well. I am very thankful of my parents, they let me work in there back yard with this view!!!! MIDS-HIGHS 8-Rockford Fosgate Punch Pro 6.5's for now.... 2-Rockford Fosgate Punch Pro 8's 4-Rockford Fosgate Punch Pro 1'' Neodymium tweeters 2-Rockford Fosgate Punch Pro 10's AMPLIFIERS 4-Rockford Fosgate T2500-1bdCP 2-Rockford Fosgate T1000-4ad 1-Rockford Fosgate T800-4ad PROCESSING 1-Rockford Fosgate 3SIXTY.3 SUBWOOFERS 2-Rockford Fosgate T3S2 19's NEODYMIUM
cole00c7r Posted February 4, 2015 Author Report Posted February 4, 2015 During most all of my building I always had help from my friends........ a huge thanks to all of them....even when they troll the crap out of me haha, so a huge thanks to them and everybody else who helped me build! Good thing one of them has a truck haha or I would have had to make multiple trips to the Depot to get mdf. The sheets fit perfect in the bed, this is only a couple sheets. I bought about 7-8 haha While I was there I got some threaded inserts and allen bolts along with some new router bits! MIDS-HIGHS 8-Rockford Fosgate Punch Pro 6.5's for now.... 2-Rockford Fosgate Punch Pro 8's 4-Rockford Fosgate Punch Pro 1'' Neodymium tweeters 2-Rockford Fosgate Punch Pro 10's AMPLIFIERS 4-Rockford Fosgate T2500-1bdCP 2-Rockford Fosgate T1000-4ad 1-Rockford Fosgate T800-4ad PROCESSING 1-Rockford Fosgate 3SIXTY.3 SUBWOOFERS 2-Rockford Fosgate T3S2 19's NEODYMIUM
cole00c7r Posted February 4, 2015 Author Report Posted February 4, 2015 Alright, so I have made three single sub enclosures while i was waiting for my second sub to come in. I didnt take many pictures of them because they were just temporary. Once I received my second sub I built two enclosures so i will post both of them up. Here is the start of the baffle, I only did a double baffle. I used screws and tightbond two. Here is a picture of my twins lol they are huge! They are dusty but oh well, I cleaned them off later....also hide your eyes from the hideous box they are on! This is the first enclosure I built, it was tuned to around 28hz using Torres but it didnt have enough net volume, I loved the port because I could crawl into it and I could float hats and towels in it! I know that it is frowned upon to put your amp on the enclosure so I did anyway lol for about a week, then I relocated it to somewhere safe!!! I also didnt have the gain set anywhere near where it should be for full output. I ran just the one set of power into the amp from the XS power d3100 because I was going to change it a week after. After about a week I decided that I wanted to make another box because this one was just off and didnt have the range I wanted so I started to build a new enclosure. I designed it using Torres and some math! I didnt get very many pictures at first but here they are. Here are some 45s I sealed up the box and i used my flush trim bit to cut out the port. Here is a picture of adding a new double baffle and port bracing! I also used the sub for weight lol \ There is my most current picture of my box, I have added some more bracing and some other little things. This weekend I am going to start on door pods so I will update when I have pictures! MIDS-HIGHS 8-Rockford Fosgate Punch Pro 6.5's for now.... 2-Rockford Fosgate Punch Pro 8's 4-Rockford Fosgate Punch Pro 1'' Neodymium tweeters 2-Rockford Fosgate Punch Pro 10's AMPLIFIERS 4-Rockford Fosgate T2500-1bdCP 2-Rockford Fosgate T1000-4ad 1-Rockford Fosgate T800-4ad PROCESSING 1-Rockford Fosgate 3SIXTY.3 SUBWOOFERS 2-Rockford Fosgate T3S2 19's NEODYMIUM
Jeff4661 Posted February 4, 2015 Report Posted February 4, 2015 Looks pretty good so far man ? . If I may ask.. why Did you do the 2 ground runs from the battery back? Instead of just grounding to the frame in the rear? Regardless I'm tuned in Current build 05 Yukon SLT http://www.stevemeadedesigns.com/board/topic/195350-jeffs-05-yukong-wall-build/
cole00c7r Posted February 4, 2015 Author Report Posted February 4, 2015 Looks pretty good so far man ? . If I may ask.. why Did you do the 2 ground runs from the battery back? Instead of just grounding to the frame in the rear? Regardless I'm tuned in Thanks for looking, I did the two runs back just because really, I wanted a good ground I guess haha, also If I was going to upgrade soon I could always throw some wire loom on the wire so it was all the same color and use it for more positive runs back. Thanks for looking! MIDS-HIGHS 8-Rockford Fosgate Punch Pro 6.5's for now.... 2-Rockford Fosgate Punch Pro 8's 4-Rockford Fosgate Punch Pro 1'' Neodymium tweeters 2-Rockford Fosgate Punch Pro 10's AMPLIFIERS 4-Rockford Fosgate T2500-1bdCP 2-Rockford Fosgate T1000-4ad 1-Rockford Fosgate T800-4ad PROCESSING 1-Rockford Fosgate 3SIXTY.3 SUBWOOFERS 2-Rockford Fosgate T3S2 19's NEODYMIUM
Jeff4661 Posted February 5, 2015 Report Posted February 5, 2015 Looks pretty good so far man ? . If I may ask.. why Did you do the 2 ground runs from the battery back? Instead of just grounding to the frame in the rear? Regardless I'm tuned in Thanks for looking, I did the two runs back just because really, I wanted a good ground I guess haha, also If I was going to upgrade soon I could always throw some wire loom on the wire so it was all the same color and use it for more positive runs back. Thanks for looking! That's a good idea.. Current build 05 Yukon SLT http://www.stevemeadedesigns.com/board/topic/195350-jeffs-05-yukong-wall-build/
notorious97200 Posted February 5, 2015 Report Posted February 5, 2015 You're taking your time to do it right. I'm tuned in. What do you plan for your front stage ? black BMW X1 2.0 l 192 hp OEM head unit, Amplifiers : Audison AP 8.9 with integrated DSP and Ampere Audio 1200. Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats. 2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
cole00c7r Posted February 5, 2015 Author Report Posted February 5, 2015 Looks pretty good so far man ? . If I may ask.. why Did you do the 2 ground runs from the battery back? Instead of just grounding to the frame in the rear? Regardless I'm tuned in Thanks for looking, I did the two runs back just because really, I wanted a good ground I guess haha, also If I was going to upgrade soon I could always throw some wire loom on the wire so it was all the same color and use it for more positive runs back. Thanks for looking! That's a good idea.. Thanks, it hopefully will work well! MIDS-HIGHS 8-Rockford Fosgate Punch Pro 6.5's for now.... 2-Rockford Fosgate Punch Pro 8's 4-Rockford Fosgate Punch Pro 1'' Neodymium tweeters 2-Rockford Fosgate Punch Pro 10's AMPLIFIERS 4-Rockford Fosgate T2500-1bdCP 2-Rockford Fosgate T1000-4ad 1-Rockford Fosgate T800-4ad PROCESSING 1-Rockford Fosgate 3SIXTY.3 SUBWOOFERS 2-Rockford Fosgate T3S2 19's NEODYMIUM
cole00c7r Posted February 5, 2015 Author Report Posted February 5, 2015 You're taking your time to do it right. I'm tuned in. What do you plan for your front stage ? Well I purchased a sax125.4 and I just got some pwx 6.5's at my door today, so I'll post updates this weekend! MIDS-HIGHS 8-Rockford Fosgate Punch Pro 6.5's for now.... 2-Rockford Fosgate Punch Pro 8's 4-Rockford Fosgate Punch Pro 1'' Neodymium tweeters 2-Rockford Fosgate Punch Pro 10's AMPLIFIERS 4-Rockford Fosgate T2500-1bdCP 2-Rockford Fosgate T1000-4ad 1-Rockford Fosgate T800-4ad PROCESSING 1-Rockford Fosgate 3SIXTY.3 SUBWOOFERS 2-Rockford Fosgate T3S2 19's NEODYMIUM
cole00c7r Posted February 6, 2015 Author Report Posted February 6, 2015 Ok so recently I realized that my rotors had some deep gouges/ groves in them, so i purchased an EBC brake kit, I figured it would be a good idea also because I will be adding more weight and be getting bigger wheels. I was very happy with the quality of the rotors and the green pads that came with them. Here are the front This is the rear After I had removed the rear rotors i noticed that my park break shoes were worn down all the way past the brake compound lol so I replaced them also! Now my Parking brake actually works haha Dirty Dirty Rotors Fresh new rotors! I didnt get very many pictures of the other side because I noticed that my oil seal on the axle was leaking, so I had to unbolt the back of my rear differential and pull the axles out, then I sealed it all back up after I replaced the seals. I used copper high temp gasket when I put the cover back on the diff along with the oem paper gasket, So far so good! Here is the front rotor! After I installed the new rotors and pads I followed the break in procedure that EBC recommends and the brakes feel better than ever! MIDS-HIGHS 8-Rockford Fosgate Punch Pro 6.5's for now.... 2-Rockford Fosgate Punch Pro 8's 4-Rockford Fosgate Punch Pro 1'' Neodymium tweeters 2-Rockford Fosgate Punch Pro 10's AMPLIFIERS 4-Rockford Fosgate T2500-1bdCP 2-Rockford Fosgate T1000-4ad 1-Rockford Fosgate T800-4ad PROCESSING 1-Rockford Fosgate 3SIXTY.3 SUBWOOFERS 2-Rockford Fosgate T3S2 19's NEODYMIUM
