khinds94 Posted July 12, 2014 Report Posted July 12, 2014 I recently installed my xp 2000 to power my 2000d. I had 2 wires from the big 3 done (engine block and battery new run) and just got my wire to finish my last run from alt to bat pos. Before I installed the last run my voltage charged at 14.4 or 14.5 and dropped to about 12.6 to 12.7 lowest. In order to connect my last run to the alt I had to disconnect my factory wire because the bolt on the alt wasn't long enough for the factory lug and the SHCA lug to be attached. So after doing the big 3 my voltage sits at 13.3 or 13.2 highest and I'm almost positive my grounds and connections are perfect. It drops to about 11.7-11.8 worst now. Why am I not charging at 14.4? It shouldn't have to do with the factory alt to pos connections? 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
khinds94 Posted July 13, 2014 Author Report Posted July 13, 2014 Any help? 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
Sutliff Posted July 13, 2014 Report Posted July 13, 2014 Apparently not. Try "bumping" it. Zeke '14 2003 Chevy Monte Carlo SS Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/ Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build Pioneer FH-P8000BT Infinity Kappa Perfect 6.1 Fi IB3 (Two 12", 2-ohm SVC) RF T400-2 & T500-1bdCP MechMan S Series 240A XS Power D3400 & D975
_paralyzed_ Posted July 13, 2014 Report Posted July 13, 2014 Soldered or crimped lugs? A shitty connection could cause loss.
Jessica Posted July 13, 2014 Report Posted July 13, 2014 hook up your factory wire. See if the voltage comes back. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
khinds94 Posted July 13, 2014 Author Report Posted July 13, 2014 Soldered or crimped lugs? A shitty connection could cause loss. Crimped I'll double check connections 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
khinds94 Posted July 13, 2014 Author Report Posted July 13, 2014 hook up your factory wire. See if the voltage comes back. It's hard to get onto the alt but I'll try again 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
Jessica Posted July 13, 2014 Report Posted July 13, 2014 what car is this? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
khinds94 Posted July 13, 2014 Author Report Posted July 13, 2014 what car is this? It's a 2003 mercury sable. The bolt on the alt is only like 3/4 of an inch so it's hard to get both fittings on. Plus the alt is like almost under the car cause it's DOHC. 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
byers319 Posted July 13, 2014 Report Posted July 13, 2014 Some of the factory grounds have sensors on them so not having it connected COULD be causing problems
