8 10s Walled SPL Issues
Dont go getting all emotional now. Answer the question. What do you have to compare it to?
I have installed DD amps, Rockford amp, aq/sq amps, and more. I have seen DD amps in action plenty of times. Don't get me wrong they are great amps for sure. But not for me. They are (imo) power hungry and expensive. I don't care for them. My soundstream amps have done everything I have expected them to do and more. Like I said I have put them through hell and have never had an issue. They are fairly efficient, affordable, and you can wire them to pretty much anything and they will still play. So ya I have worked with and installed many other types of amps.
not power hungry at all. i think they appear power hungry to you because they are making serious power. and you are gunna have drop with serious power. they are actually very efficient. expensive well ill give you that.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
well im probably thinking back to when you were wired to 1/8 of an ohm dropping to 9 volts lol. but, in then end I run the amps I do because they do what I want them to do and more for the amount I wanna spend. It's now worth arguing about. I know you don't see them as great amps but at least your not calling them shit like Nate.
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
B2 zero.7 (5500rms) > m4 (5000rms)
But beyond the whole amp thing.
Seal off. Port plugs.. Add power... See where your at. IMO
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
you really have my interest. on your b2 stuff. lol
BMW M340 xDrive
B2 isn't magic. Their reference tweeter sucked. Their Quattro has a bug in its HPF for the mid when you try to run active. But there are plenty of things they do right and are one of the only amps I'd even dare compare to dd. I think their actually very very similar amps, one is just rated for usaci, one is not.
What I'd like to see is the newest DD audiophile component set vs my reference set. Might make for an interesting vs test.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
lol just call me so we dont clog up the thread. im off work at 530 today. plus the bump home. so later.
:morepower1:
BMW M340 xDrive
but how big is it!
12 inches wide. 24 inches long. 2.x high. Its a hair wider then a m4. Basically a m4 with triple inputs.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
But even on that not I vote sealing off, a second m4, and port plugs till you get the port area and tuning that you desire. Then rebuild to that exact spec. Or just fiberglass the port plugs in.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
but how big is it!
m4 is 9 wide and 23 long. same height. so not bad. like i said. b2 has my eye. now pricing :) and what are you clamping. ross dont even think about this lol. just get rid of the m4 and go to soundstream. b2 and dd are for people that dont like to be loud.
BMW M340 xDrive
  • Who's Online   0 Members, 0 Anonymous, 3242 Guests (See full list)
