I have 2 alts I want to run together in my 12 volt system they are internal regulated I want to run them at 15 to 15.5 volts charging as I think this is the highest safe voltage for 12 volt system plzz tell if this is possible and how to do it any import is appropriated I'm new to this
why charge so high?
I wouldn't charge over 14.8, you'll just shorten the life span of your 12v batteries, you'd be better off running a 14v system if you want charge at 15.5
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
on a 12 volt system i would not recommend charging above 14.6 for extended periods. especially if batteries are charged.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
double
BMW M340 xDrive
wiht the info you've provide ill answer with the equivalent. With wire
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 9650 Guests (See full list)
