Seqioua- MAJOR REBUILD [3 stereo integrity ht 18s 3:1 4th c-pillar wall][3 audiopipe acpl 1500.1d]
Incoming awesome pics, got it playing and it sounded great. Got much lower than my last build. But holy voltage drop I need an alt like yesterday. Bad news... At medium volume a woofer blew. Totally pissed. Unhook the blow sub and amp and the damn thing is way louder. Very confused.
56540E6A-4F76-496B-846C-F493FDECE18D_zps
AD15E62B-499F-40A3-82C1-5C40CA974DEF_zps
0D6745D7-329B-49F0-B0EB-D69772CA5453_zps
BAF39E20-27DA-430D-B397-7BBD5539AF16_zps
00ACD9D8-5F2E-4F92-9626-705D376ADF37_zps
7253B82F-3277-4ED5-BFDD-92B1529DE75F_zps
BE1F5821-9501-449B-A251-20A4FBAE5646_zps
3CAA9318-05C3-4783-AD1B-85E36629395D_zps
B740D2E3-B5C5-47BC-BF61-905C710D7FCB_zps
D73F694A-B7BD-46A8-B2EC-501D322A70A5_zps
29287A77-44A5-4C41-A406-82511EE4A04F_zps
6A5E19E6-63A4-4D6D-B1B6-FCD77E665732_zps
4D510D9B-BC48-4AA5-9457-2100841E1044_zps
Possible u changed the impeadance and now it is at a lower ohmage and pushing more watts to the subs that are working or..the blown sub now acts as a passive radiator idk. Or maybe the fact that you have so much airspaxe for only two drivers..i would not bump hard til you get that sub replaced if i were you. You may overwork the suspensions on the two subs with all that airspace
You need trunk space to get groceries and shit...bitches love groceries
I double and triple checked all my wiring and nothing was out of place. Each sub was on its on amp which where bridged together. Gain was set considerably low because I expected the voltage go way down. And I always watch my voltage, second it goes down to low 12s I back it off. I'm going to try to contact the company and see if there is anything they can do for me
It could be the airspace. You can pull out the broken sub, displace the volume to match what you had for each sub and retest with the sub back in and see what happens. That way you know if it's the airspace or not.
Well right now only running the 1 sub until I get my batts and alt because my voltage. But I will try that
Bad amp? How did you gain match the amps?
Well as per the audiopipe manual I set my gain on the master amp and use a single rca between each amp. Similar to the data cable for amps that have a master and slave setting
