moredbs Posted July 29, 2014 Report Posted July 29, 2014 I plan on getting a second battery as my Tahoe has another battery tray on the passenger side but I don't want to get it yet if this issue isn't fixed depends on what amp your gonna run and how much wattage. I'm assuming over 2,000 cause you purchased a alternator first
Broke_Audio_Addict Posted July 29, 2014 Report Posted July 29, 2014 Did you replace your serpentine belt and tensioner pulley when you installed the new belt? Also go back through and make sure all power and grounds are good and tight. Are you just going by the cluster or do you have a multimeter you are testing this with. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Broke_Audio_Addict Posted July 29, 2014 Report Posted July 29, 2014 Also does this happen if you floor the gas pedal during acceleration? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
DubNDodge Posted July 29, 2014 Report Posted July 29, 2014 Smaller pulley is easy to change. Yes get with DC, they will most likely hook you up. Yeah they will. just give them 5 months to get a pulley to you. Ask snowdrifter. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Broke_Audio_Addict Posted July 29, 2014 Report Posted July 29, 2014 One more question does your suv have the tow/haul button and if you put it in tow haul does the issue go away? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Shadow_80613 Posted July 29, 2014 Author Report Posted July 29, 2014 I plan on getting a second battery as my Tahoe has another battery tray on the passenger side but I don't want to get it yet if this issue isn't fixeddepends on what amp your gonna run and how much wattage. I'm assuming over 2,000 cause you purchased a alternator first I have a Aq 3500.1 I am going to run
Shadow_80613 Posted July 29, 2014 Author Report Posted July 29, 2014 Did you replace your serpentine belt and tensioner pulley when you installed the new belt? Also go back through and make sure all power and grounds are good and tight. Are you just going by the cluster or do you have a multimeter you are testing this with. I did replace the serpentine belt with a gates brand one but no I did not change the tensioner pulley should I do that? And I use a digital multimeter 2 different ones and they both read the same voltage
CNF Kevosinn Posted July 29, 2014 Report Posted July 29, 2014 yaaaaaa anddddd PCM controlled not the alts fault. every 05 and newer has this. *** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ ) "kevosinn's" astro van 8 custom Sundown Zv4 18's 4 Sundown scv 6000's CNF Distribution CNC parts Skyhigh wire some batteries SMD Meters and tools used on the installhttp://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/ 16,000 watt walled silverado build.http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/ 8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60TEAM CNF Distribution
Shadow_80613 Posted July 29, 2014 Author Report Posted July 29, 2014 So I just got off work and checked my battery it is sitting at 12.6V which worries me a bit because the batterys new and I just charged it the other day we'll I decided to put it in tow mode and when I started it up All was good it started in that spot for a good while well as soon as I got home and parked I sat in there for awhile to watch it with the truck still on and it dropped It did better in tow mode but still it dropped could this be because of the battery
Shadow_80613 Posted July 29, 2014 Author Report Posted July 29, 2014 Even parked when my voltage dropped I tried pressing the gas to see if it would go back up but it did not
