Box help?
lowrhadur
Could someone check out this box design and tell me if im right on my math?
is the port dimension right for the sub?
will this configuration work? any other info/advice you can give me
id be happy to pay someone to help me get this right.
i don't want to waste material and labor building the wrong box
02 GMC Yukon
Pioneer 8600BS headunit
pioneer gm-d9601 amp 1200watts RMS @ 1 OHM
DC LvL 3 15" Dual 2 OHM
Box:
width: 24.5"
height: 20.75"
depth: 18.5"
port width: 2.5"
port height: 18.5"
port length 1: 15.25"
port length 2: 13"
total port length: 32.75
Box volume: 3.43cu. ft after port
After sub displacement i should be around 3.25cu. and
between 31-32hz if this is right.
sub firing up, ported to the back
Sorry man, the box gurus have been on vacation apparently.
Did the math the old fashioned way, or what did you use to come up with the port length/area?
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
Just by using the numbers you provided I came up with:
Gross Volume - 4.36
Port Volume - 1.48
Physical Port length - 29.50
Port Area - 46.25
Port Area per Foot - 17.13
Net Volume - 2.70
Tuning Frequency - 34.68
RE box calculator on this one.
Im anxious to build. My sub will be here early next week and this prefab just aint gonna cut it lol...
while i dont know about that sub and vehicle, i will say this...the box does need some additional bracing. I would also STRONGLY encourage you to round off the edges on the boards that make your port. Those hard corners will cause a lot of turbulence and make the port be inefficient .
also, on the width and depth on the bottom board that your driver mounts to. id shorten up those dimensions by 1.5" each (assuming 3/4" wood) and then extend your sides, front, and back by 3/4" . you keep your same outside over all dimensions and yet in my opinion have a much stronger enclosure
  • Who's Online   2 Members, 0 Anonymous, 1378 Guests (See full list)
