lowrhadur Posted August 1, 2014 Report Posted August 1, 2014 Could someone check out this box design and tell me if im right on my math? is the port dimension right for the sub? will this configuration work? any other info/advice you can give me id be happy to pay someone to help me get this right. i don't want to waste material and labor building the wrong box 02 GMC Yukon Pioneer 8600BS headunit pioneer gm-d9601 amp 1200watts RMS @ 1 OHM DC LvL 3 15" Dual 2 OHM Box: width: 24.5" height: 20.75" depth: 18.5" port width: 2.5" port height: 18.5" port length 1: 15.25" port length 2: 13" total port length: 32.75 Box volume: 3.43cu. ft after port After sub displacement i should be around 3.25cu. and between 31-32hz if this is right. sub firing up, ported to the back
philrab Posted August 2, 2014 Report Posted August 2, 2014 Sorry man, the box gurus have been on vacation apparently. Did the math the old fashioned way, or what did you use to come up with the port length/area? 2015 Toyota Tacoma Build Thread 2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount. Build Thread 1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers. 1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
Pioneerchuck Posted August 2, 2014 Report Posted August 2, 2014 Just by using the numbers you provided I came up with: Gross Volume - 4.36 Port Volume - 1.48 Physical Port length - 29.50 Port Area - 46.25 Port Area per Foot - 17.13 Net Volume - 2.70 Tuning Frequency - 34.68
timc31610 Posted August 3, 2014 Report Posted August 3, 2014 You were pretty close. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
lowrhadur Posted August 3, 2014 Author Report Posted August 3, 2014 Sorry man, the box gurus have been on vacation apparently. Did the math the old fashioned way, or what did you use to come up with the port length/area? Just by using the numbers you provided I came up with: Gross Volume - 4.36 Port Volume - 1.48 Physical Port length - 29.50 Port Area - 46.25 Port Area per Foot - 17.13 Net Volume - 2.70 Tuning Frequency - 34.68 RE box calculator on this one. Im anxious to build. My sub will be here early next week and this prefab just aint gonna cut it lol...
lowrhadur Posted August 3, 2014 Author Report Posted August 3, 2014 had a guy on another forum tell me this "However off of just math I am showing 3 cu ft. After displacement. And 32.9hz tuning. Your port length is actually 31.5."
lowrhadur Posted August 3, 2014 Author Report Posted August 3, 2014 You were pretty close. thanks man, needed some verification. Do you think this box will work well with sub firing up ported back with this dc lvl3 15?
Ritch40 Posted August 3, 2014 Report Posted August 3, 2014 while i dont know about that sub and vehicle, i will say this...the box does need some additional bracing. I would also STRONGLY encourage you to round off the edges on the boards that make your port. Those hard corners will cause a lot of turbulence and make the port be inefficient . also, on the width and depth on the bottom board that your driver mounts to. id shorten up those dimensions by 1.5" each (assuming 3/4" wood) and then extend your sides, front, and back by 3/4" . you keep your same outside over all dimensions and yet in my opinion have a much stronger enclosure
timc31610 Posted August 3, 2014 Report Posted August 3, 2014 I would use a couple of 1 1/4" dowel rods for bracing. Should sound good. And definitely round all the port edges! My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
