Giuseqpe Posted August 5, 2014 Report Posted August 5, 2014 Hi I'm just wondering if anyone has run a m3b at 0.5 ohm daily? I have a singer 240, 1 xs d3400 and 2 d3100. 2 runs from alt and 2 runs between each battery. I'm wired at 1ohm at the moment and barely drop. Just wondering if the amp can handle 0.5ohm daily. Thanks
Bump4life Posted August 5, 2014 Report Posted August 5, 2014 yes it can. as long as your electrical is good. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
Swordlordboy1234 Posted August 5, 2014 Report Posted August 5, 2014 I wanna run .5 ohms daily like all the cool kids. Can I have it in a 4th order too just to fit in? Edit: OP, yes you can run most well made Korean amps at lower then 1ohm load.... Does it mean you should? Most likely not... Especially not daily.... Especially if you don't know what your doing. Best advise I can give. When you wanna run under 1ohm nominal. Take your amps wattage.. (3800 of the m3b) and build to about 40% more then you would normally need. With that calculation I get 5,320 watts. So running a m3b at .5 daily you should build your electrical as if you were going to run a 5000 watt amp at 1ohm. Hope that helps. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
martydmb Posted August 5, 2014 Report Posted August 5, 2014 Dont mind this guy^^^ 05 dodge magnum rt DEH-80PRS Rockford fosgate T600.4 st200 tweeters Sundown Neo Pro 6.5 v2's 2 Saz-3500v2- Toolmaker dual 1/0 inputs 2 Sundown ZV4 12" D1 1/0 Sky High Power wire OFC 3 XS D3100- Toolmaker battery terminals Mechman 320 Amp Alt Smd Voltmeter KnuKoncept 1/0 OFC
Swordlordboy1234 Posted August 5, 2014 Report Posted August 5, 2014 Dont mind this guy^^^ What's not to mind about correct info? Can it be run on less? Sure.. Take my build, stronger amp, and less electrical then I just reccomended to OP but I also know my stuff is set up correct and I always keep an eye on my voltage even though it never touches below 13.1 But if you gotta ask, the people giving feedback have to assume they do not know better and need an overkill answer. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
martydmb Posted August 5, 2014 Report Posted August 5, 2014 Should be obvious that it was about you comment before your edit and not what was in your edit?? 05 dodge magnum rt DEH-80PRS Rockford fosgate T600.4 st200 tweeters Sundown Neo Pro 6.5 v2's 2 Saz-3500v2- Toolmaker dual 1/0 inputs 2 Sundown ZV4 12" D1 1/0 Sky High Power wire OFC 3 XS D3100- Toolmaker battery terminals Mechman 320 Amp Alt Smd Voltmeter KnuKoncept 1/0 OFC
DrewJones Posted August 5, 2014 Report Posted August 5, 2014 If you have to ask, you probably shouldn't. TEAM SOUTH Bassahaulic Productions The ONLY Bright Atlantic Blue DiamondBoxx L Drew Jones Bassahaulic Productions 4 SSA ZCON 15"s 2 Sundown SCV-6000's 6 AGM G31's 161.6 @ 40Hz Outlaw 159.8 @ 36Hz Legal ┌∩┐(◣_◢)┌∩┐
GSanders17 Posted August 6, 2014 Report Posted August 6, 2014 Yes you can. I run a M2b at .35 daily and no fucks are given!
Krakin Posted October 7, 2014 Report Posted October 7, 2014 Lower resistance is not a good thing. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
