Could I benefit from running ground from front battery to back?
I'm fixing up my grounds tomorrow for my rear battery and my front.and was wondering if I would benefit at all to run 4ga OFC from front battery to back?
It's just extra I had laying around from an old build and don't have enough of my 0ga to do it.. Everything else in my set up is all 0ga OFC..
'97 Explorer
2 Sundown SA 15's
SQ 2200D
Kinetik KHC1800 (Front)
Kinetik KHC 2000 (Back)
KnuKonceptz 1/0 OFC
130A Alt + Big 3
What do you mean "fixing"? Or do you already have a 0G short ground? I don't think it would matter much, plus I always say "that's why amp kits come with short grounds" and my rule is shorter the cable the better. :good:
Electricity will always go to the path of least resistance as I'm sure you know. Therefore if you add it ... And you see no gain.. It's because your body grounds have less resistance.
Short answer. It won't hurt. But obviously a 1/0 dedicated ground would be best.
In my opinion it won't help.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
I've heard the shortest run possible for grounds is best. I've also seen many people do front to back (or back to front, whatever). I've seen people actually do both. No one has had any issues in any of those ways. It's all about personal preference...when it's done right.
Sheena = pedobear
By fixing I mean grounding to either my rear strut tower or finding a way to get to frame.. Currently it's grounded on a this piece of metal under my flap behind my back seats..
'97 Explorer
2 Sundown SA 15's
SQ 2200D
KnuKonceptz 1/0 OFC
130A Alt + Big 3
Go with 1/0 to the strut tower in the rear. 100%... That made a huge improvement for me from my random metal ground in the back... .. Then when I upgraded power I did a ground to the front strut tower. Gave me slightly better voltage.
Then when I upgraded power again I connected the strut tower grounds and that gave me another slight improvement.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Yeah I'll definitely do that then wondering if ill see any gain on the meter from changing grounds.. Guess ill find it at comp Friday..
Bad thing is I have no idea how to get my damn panel off the back..
'97 Explorer
2 Sundown SA 15's
SQ 2200D
KnuKonceptz 1/0 OFC
130A Alt + Big 3
this has been done so many times. YouTube that very question. you'll find a few hundred vids on it. and every one shows that running from back to front is not nearly as good as a short ground to the frame. some times the voltage drop is 1/2volts harder when run front to back. if you have a short 0g ground don't bother! and even if you only have a 4g ground don't run it all the way back. always try and make it 3ft or less.
Just a waste of time,money,and wire
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
Just ground the rear batt itself. Adding a full run probably isn't going to give you a big enough difference for you to notice
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
i will attest to this statement.
In my application i removed my ground runs ( 2 runs of 4/0) and just had my runs of positive from front to rear and grounded everything in the rear. I seen a .6 volt increase in doing this. I was floored!
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
  • Who's Online   0 Members, 0 Anonymous, 7073 Guests (See full list)
