Ideas for amp fans
BigManAC
The air in my trunk is stagnant due to it being sealed off from the cab. My amp would be a lot happier if it had some air flow going to it. The only problem is that im not sure if I should do just one side because of the power and speaker inputs would be blocking where the fans would go. TIA for any input.
28E4DF67-9C7D-4CE7-B524-7FA167BE7C84_zps
B9587199-C115-477B-A0FE-E82B3D23F638_zps
661A98F7-5464-4CF1-8332-B5D8F5A6AC66_zps
B6283B04-9E3C-43AA-ABFA-A5DE45FE5D76_zps
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
try the one fan on the side...check out the results...you could always rebuild the amp rack to allow more venting/ more space for a second fan in a push/pull configuration. .02
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
The best of the best, i have a pair of delta's going strong every day for 10 years straight now.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007998%2050001445&IsNodeId=1
EDIT: If you do decide to go with them i would get a controller and DO NOT stick a finger near the blades unless you want to remove them.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Alright thanks man. Yeah I want to keep my fingers, they tend to help with day to day things.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
  • Who's Online   1 Member, 0 Anonymous, 773 Guests (See full list)
